FS: Parting out 88 crx si and b16a LS stuff
Make offers
FS: used 88+civic/crx complete front fastbrake kit uses gsr calipers
FS: 88-91 crx si intake manifold complete with fuel injectors and rail/throttle body,
manifold is ported and polished in the opening and on the runners. Injector resistor box and ecu for a dual to multipoint fuel injection conversion.
FS: JDM vision corners for 92-95 civic real deal authentic brand new *sold*
FS: autometer oil pressure electrical sender unit only no gauge
FS: Pair of sprint springs front only, cut still stiff with nice drop
FS: 88-91 crx starter from autozone low mileage
FS: 88 crx si motor mounts and brackets
FS: 88-91 crx si upper and lower heat shield
FS: 88 crx si front upper control arms
FS: 88 crx si front suspension fork
FS: 88 crx si front sway bar
FS: 88 crx headliner
FS: 88-91 crx stock d series header upper portion 4-2-1
FS: 88 crx si steering rack
FS: 88 crx front and rear bumper
FS: 88 crx si cluster cover
FS: 88 crx glove box black *sold*
FS: 88 crx si defrost button
FS: 88 crx hf gauge cluster parting out temp and gas gauge
FS: 88 crx si dimmer switch
FS: 88 crx rear speaker mount bracket
FS: 88 crx si rear cargo cover is in two pieces *sold*
FS: 88 crx si storage compartment *sold*
FS: 88 crx si passenger and driver interior pillars
FS: 88 crx si dome light
FS: DOHC upper ZC timing belt cover *sold*
FS: single ZC motor runs great minus distributor and flywheel *sold*
FS: 88 crx si ecu pm6
FS: 88 crx AC system parts and various AC hoses
FS: 88 crx climate control small crack *sold*
FS: 88 crx fuse box under dash
FS: 88 crx fuse panel cover inside of car
FS: 88 crx driver and passenger sun visors
FS: 88 crx front suspension hub assembly
FS: rear crx hatch with and without broken glass ebrake assembly
FS: 88 crx main relay
FS: 88 crx si dash
FS: window wiper motor system
FS: Sunroof rails and assembly
FS: 88 crx injector resistor box
FS: 88-91 crx radiator support *sold*
FS: 88 crx rear cargo cover in two peices and storage compartment *sold*
FS: 88 crx si upper timing belt cover
FS: used brake booster bought from autozone has 100 miles on it for the 88-91 crx
FS: 88 crx rear tail lights good shape with crx sticker*sold*
FS: 88 crx center console
FS: 88 crx stereo holder/ashtray/cigarette lighter plastic piece *sold*
FS: 88 crx si blower the one under the dash
FS: 88 crx si driver side engine bracket timing belt side
FS: 88 crx rear tranny bracket
FS: 88 crx rear view mirror
FS: 88 crx si front calipers
FS: 2 88 crx si fuel rails
FS: 88 crx si clock
FS: 88-91 crx shiflinkage *sold*
FS: 88 crx si passenger seat $90.00 *sold*
FS: 88 crx Driver and passenger window
Fs: 88 crx driver and passenger window regulator
FS: 88 crx rear hatch no wiper
FS: 88 crx si complete clutch, brake, gas assembly perfect for auto to 5 speed includes all bolts *sold*
FS: 88 crx si sunroof control botton *sold*
FS: fuse box in the engine bay
FS: 88 crx si map sensor and two other tiny canisters sensors related to smog
FS: JDM SiR 88-89 crx corner lenses $75.00 *sold*
FS: 88 crx shell front end damge pm me for more details *sold*
*inquire on any other stock interior paneling not listed*
*If you need a stock crx part not listed chances are I might have it still on my crx*
FS: 88-91 JDM crx b16a intake tube
FS: b16a crankshaft
FS: 1g b16a vtec solenoid bottom portion only
FS: 4 1g b16a injectors
FS: 4 b16a pr3 pistons $75.00
FS: 4 b16a rods
FS: b16a throttle body minus tps sensor
FS: b16a engine block water coolant pipe and peice that holds the thermostat
FS: b16a intake and exhaust cams with gears
FS: b16a main bearing caps with bolts
FS: 1g b16a intake manifold complete with injectors, fuel rail, minus throttle body
FS: 1g b16a downpipe and upper portion of header
FS: b16a used water pump
FS: 1g b16a fuel rail
FS: 95 GSR fuel pressure regulator
FS: 86-89 integra ZC oil pan
FS: 86-87 integra ZC valve says HONDA on it in big letters painted blue
FS: 90-93 integra rear trailing disk brake and ebrake cables *sold*
FS: 90-93 rear teg lCA
FS: 95 LS intake manifold bare *sold*
FS: 95 LS driver side engine bracket timing belt side
FS: 95 Ls alternator brackets
FS: 94+GSR upper engine mount driver side
FS: 95 Ls head complete *sold*
FS: new exedy stock clutch disc for the 94+ integra
PM me with any questions or email me at johny5w64@aol.com
[Modified by JohnnyEF, 5:44 PM 2/15/2003]
[Modified by JohnnyEF, 10:50 PM 2/19/2003]
[Modified by JohnnyEF, 6:18 PM 3/13/2003]
[Modified by JohnnyEF, 4:48 PM 3/14/2003]
FS: 88 crx si dash
FS: 88 crx si clock
FS: b16a crankshaft
FS: 4 b16a rods
do you have the si knuckle/hub???
hey how much for that ECU? also if ur parting it out, how much for both door panels and what color and condition?
i need the engine harness and ECU harness
Is the harness cut in any places or modified anywhere?
thanks and TTT
thanks and TTT
and do you happen to have the LS rods?
interested in those, and LS rods. possible B16 rods, but ill have to check around a lil bit.
Are these smoked? Pictures?
Yes they are smoked deep rich amber color. The borders are black with a grey backside not silver or chrome. I will email you a pic tonight
