Still the unanswered question for my 92 Prelude
Old Dec 28, 2002 | 10:17 PM
HeeroZ's Avatar
Default Still the unanswered question for the 92 Prelude
Has anyone ever found the correct solution on fixing the idling problem? Here's the factor...
It rattles when the temperature meter reachs the normal halfway. The engine would just not idle high, it'll be below half of 1, and the car would stall/rattle. I've heard of things like replace ECU, check vacumm lines, set idleing nut higher. But which one works? Do you guys think a simple tune up will fix it?
I'm sure many Prelude owners out there are looking for an answer too.
[Modified by HeeroZ, 7:20 AM 12/29/2002]
[Modified by HeeroZ, 7:27 AM 12/29/2002]
Old Dec 28, 2002 | 10:46 PM
ViruX's Avatar
Default Re: Still the unanswered question for the 92 Prelude (HeeroZ)
i dont think replacing the ECU would do any good, unless your car was in a flood. check the vacum lines, spark plugs, spark plug wires, put some injector cleaner in, bump up the idle nut..........if after you do all that stuff it still doesnt idle right, then try the tune-up or post up here again....
-Vi
Old Dec 28, 2002 | 11:42 PM
HeeroZ's Avatar
Default Re: Still the unanswered question for the 92 Prelude (ViruX)
yea, i'm planning to do some of those soon. i'll get back to ya if i can, thanks.
hey, i have a question. i'm not very sure of where the EGR is at, or what it even is. can someone give me details or explain to me, thanks.
[Modified by HeeroZ, 10:08 PM 12/29/2002]
Old Dec 29, 2002 | 01:26 PM
HeeroZ's Avatar
just bumping this up a little, sorry
Old Dec 29, 2002 | 06:15 PM
ViruX's Avatar
EGR is Exhaust Gas Reticulation.....basicly what it does is put hot exhaust gases back through the engine to heat it up faster.....it should be on the left side of the engine.
-Vi
Old Dec 29, 2002 | 10:33 PM
HeeroZ's Avatar
Oh I see, I'm gonna look into tomorrow morning. Hopefully I can find something. Thanks man!
Old Dec 31, 2002 | 09:34 AM
bboyprelude's Avatar
i have the same idleing problem. still have yet to fix it, but i went to mr. transmission and they told me that i need to replace my entire idle control assembly. 600 dollars i think
Old Jan 1, 2003 | 01:33 AM
HeeroZ's Avatar
Default Re: Still the unanswered question for the 92 Prelude (bboyprelude)
oh man you serious?! i aint gonna pay 600 bucks, there must be a cheaper way
dmcclure111
Mar 12, 2010 02:11 PM
gsrjdm00
Jan 4, 2009 02:44 PM
alexaccord
May 21, 2007 07:50 AM
delguiner
Aug 12, 2004 03:23 AM
