whats the biggest you can resleeve a b16 motor?
Old Dec 28, 2002 | 09:32 PM
SiRkid's Avatar
Default whats the biggest you can resleeve a b16 motor?
i think ive seen 1.7 something.... is that it?
im thinking re sleeve 1.6 block
or should I get a 1.8 block and later resleeve(I dont think I can afford to get a 1.8 , pistons rods and resleeve all in one shot). Im thinking since im on somewhat of a tight budget I should just work with what I have.(but im still worried that I wont flow enough air for my turbo)
any ideas?
[Modified by SiRkid, 6:33 AM 12/29/2002]
Old Dec 28, 2002 | 11:49 PM
Kwuaymaikrup's Avatar
Default Re: whats the biggest you can resleeve a b16 motor? (SiRkid)
Why not resleeve it and drop in a 1.8l crank when you have the cash? If not leave it alone. How much power are you looking to make? There was a sleeved 1.6l (1.74l) on here making just over 500hp. Just my .02 Good luck.
Ryan
Old Dec 29, 2002 | 12:00 AM
T-sohctec's Avatar
Go with a 1.8 it's gonna cause you less hassle, and you'll be able to make
nice power(I.E. torque) "as is".
Old Dec 29, 2002 | 07:39 AM
The sweed's Avatar
Default Re: whats the biggest you can resleeve a b16 motor? (T-sohctec)
Golden eagle can hook you up with a deck plate, 84mm bore sleeves and a eagel stroker crank and you end upp with a 2,2l with 1,75 rod stroke raito.
Old Dec 29, 2002 | 08:16 AM
boosted hybrid's Avatar
Default Re: whats the biggest you can resleeve a b16 motor? (The sweed)
I have boosted a few b16a's, trust me its a world of difference between the two. With you large turbo you are better off going with the 1.8, and then later resleeved that to a 2.0 liter. You can make power and torque so much easier with the larger displacement.
Old Dec 29, 2002 | 02:02 PM
SiRkid's Avatar
Default Re: whats the biggest you can resleeve a b16 motor? (boosted hybrid)
i know...
hmmm, thanks for the help guys.
any other opinions?
Old Dec 29, 2002 | 02:23 PM
Phoenix GSR's Avatar
does anyone here use the golden eagle deck plate/stroker kit?
I wonder how the reliablility is...
Boosted Dad
Nov 19, 2006 03:05 PM
cltitus
Oct 16, 2005 03:48 AM
EVOCELICA
Feb 25, 2003 11:26 AM
