question for FI guys
Old Dec 28, 2002 | 09:08 PM
ITR41's Avatar
New User
Default question for FI guys
have any of you ever heard of the greddy turbo kit on a ITR?....will I be the first?
Old Dec 28, 2002 | 09:10 PM
BlueR's Avatar
Default Re: question for FI guys (ITR41)
greddy uses really small turbos in there kits, correct?
Old Dec 28, 2002 | 09:14 PM
(__________)'s Avatar
Default Re: question for FI guys (BlueR)
Never really done much research on turbos but i know the one for the SOHC is small so I figure the B series one is small too
Old Dec 28, 2002 | 09:17 PM
ITR41's Avatar
New User
Default Re: question for FI guys (steves98itr247)
the DOHC turbos are TD-05 18g's....it will push 20psi out of it pretty easily. the sohc's a TD-04 housings...I am not sure but I think it is a 14g....basically I want a quick spooling turbo that will push some power.....and I got a super good deal on the kit
Old Dec 28, 2002 | 09:22 PM
Reid's Avatar
Global Moderator
What are you basing this on?
People on this board are reporting that the wastegate doesn't regulate boost very well over 17 psi.
Old Dec 28, 2002 | 09:25 PM
ITR41's Avatar
New User
Default Re: question for FI guys (Reid)
well, the 18g itself will push that....you need to upgrade the WG flapper if you want to run high boost....I have a ITR here. I am runnin 10psi on a inline pro head gasket with a ton of fuel and tuning when the car is on the road. the 18g is a DSM turbo so you can use the big WG flappers they use
Old Dec 28, 2002 | 09:26 PM
vtec.dc2's Avatar
although it will spool quickly, their small turbo might not provide the powerband on top end. its not the best kit out there in my opinion, custom is the way to go... - research and put your parts together. - consider all modification you may need in the future, and buy the right parts in first place, so you don't mess it up and spend more money.
from https://honda-tech.com/zerothread?id=369119 - don't know for sure if its greddy, i thought the heatshield kinda looks like it.
copy/paste
http://www.imagestation.com/picture/...f.jpg.orig.jpg
[Modified by vtec.dc2, 1:29 AM 12/29/2002]
Old Dec 28, 2002 | 09:30 PM
ITR41's Avatar
New User
Default Re: question for FI guys (vtec.dc2)
ohh it's not the best out there, but I want to be different...not many people buy this kit and really fiddle with it....I mean it is a 50state legal kit . the DP is restrictive and this kit is goin on a ITR not a GSR so it has to be modded to fit...I am porting the DP flange and runnin a custom 2.5" DP....I am also tossing the FCU and injectors and runnin 440's and a hack.....I think it will run ok
Old Dec 28, 2002 | 09:35 PM
vtec.dc2's Avatar
i'm not sure, but the kit for ls should fit better, at least inrecooler piping so you don't have to do much modifications. btw.. 50 state legal without the intercooler kit, at least without the bov
[Modified by vtec.dc2, 1:44 AM 12/29/2002]
Old Dec 28, 2002 | 09:40 PM
ITR41's Avatar
New User
I know that that LS will fit better but like I said I got a awesome deal on this kit from my friend(who is a HT member)....the kit is brand new and he is giving me the Profec-B, all gauges(egt, boost) and the entire kit with FMIC and all piping and parts
Old Dec 28, 2002 | 09:52 PM
done's Avatar
im with reid on this one..
Old Dec 28, 2002 | 10:02 PM
ITR41's Avatar
New User
Default Re: question for FI guys (Jordo)
with a upgraded flapper my friends 17c frank JR pushes 21psi with no creep at all....I am pushing 10psi here so who cares about 17psi
GreddySi99
Jul 9, 2003 10:29 AM
Buzzbomb
Jun 4, 2003 08:57 PM
GreddySi99
Feb 12, 2003 05:50 PM
