2000 USDM ITR head onto OBD1 car - how to?
What is necessary to put a OBD2 ITR head onto a B16A block that is going in a 92 GSR? I know as far a fitment and such, its a direct dropin but electrically and everything, what do I need to get/do to make this work?
if your wiring harness is from an obd1 car (or stock) change the type r's injectors from obd2 to obd1 injectors. Same with distributor.
[Modified by Ek-CoolGuy, 11:53 AM 12/29/2002]
you can use everything the same danny, just cut up your wire harness and match everything with the itr plugs if you have them...if not, switch it all to OBD1 or use the B16's plugs on teh ITR head....
If you get an ITR head, all you need to do is move everything over from your 92 GSR head, such as the distri., valvecover (if need be), complete intake manifold w/everything on it.....its all plug n' play.
MI4$DC5
May 13, 2006 09:24 AM
SiBuddy00
Sep 19, 2004 05:13 PM
