OBD0 or OBD1 Head on OBD2 B16A2
Re: OBD0 or OBD1 Head on OBD2 B16A2 (SiBuddy00)
I would use obd1 head, I believe everything will be the same as long as you use your IM, might wonna check with someone else. You might even be able to use OBDI IM with some modifications to make it smogable.
Re: OBD0 or OBD1 Head on OBD2 B16A2 (ABK)
Man dont listen to this kid he knows nothing... Assuming your in a obd1 car you can use any block with an obd1 head. Theres a differnce in the distro on each gen, which is one thing you need to change for sure, depending on what your trying for using your correct gen IM would be easiest, other wise they are for the most part they are all the same.
KYLE
KYLE
Why not put a OBD2 head on?
If you have to pick between those 2 get the OBD1 head. Much easier to work with then the OBD0. Because this way you could convert your car to a OBD1 if need be. Or just get a bare head and put all your OBD2 stuff on there then it should just go right on.
Xemu
14
11-06-2009 07:24 AM
JokerTypeR
11
07-14-2006 07:26 AM
