did a search... still have questions on type s pistons in a h23
Old Dec 28, 2002 | 07:37 PM
user 9782082308's Avatar
Default did a search... still have questions on type s pistons in a h23
I have been playing around with the idea of Type S pistons in my h23. How much will the 3.8cc differance in the head volume change my CR? Will the diff in head volume cause my valves to hit the piston? Are the rings of the Type S the same as the usdm h22? How bout the pins and retainers? Anything else I should know besides the conrod mods?
Thanks
[Modified by racerx, 11:38 PM 12/28/2002]
Old Dec 28, 2002 | 10:05 PM
red92s's Avatar
Default Re: did a search... still have questions on type s pistons in a h23 (racerx)
I believe Satan_SRV calculated that Type-S pistons on an H23 crank would produce a CR of about 12.3:1
Old Dec 29, 2002 | 12:05 AM
1fast5gp's Avatar
Default Re: did a search... still have questions on type s pistons in a h23 (red92s)
that's pretty high... gotta look into that.
Old Dec 29, 2002 | 01:07 PM
Default Re: did a search... still have questions on type s pistons in a h23 (1fast5gp)
Will I need better fuel managment than a fpr for 12.3 compression? How about valve clearance?
Old Dec 29, 2002 | 04:21 PM
red92s's Avatar
You will need some pretty good tuning to run 12.3:1 on 91 octane.
Old Dec 30, 2002 | 12:24 AM
satan_srv's Avatar
Can you say melted pistons? That's what will happen...
Great thread over on PO.com about that...
Old Dec 30, 2002 | 03:08 PM
Default Re: did a search... still have questions on type s pistons in a h23 (satan_srv)
So the only way to raise compression with pistons is to sleeve? Man, that sux!
boostdeliquent
Feb 3, 2007 07:05 AM
honda head
Apr 17, 2006 08:59 AM
j_max420
Jul 9, 2005 09:42 AM
goula SOS
Jun 21, 2003 07:14 PM
AndyD
Nov 30, 2002 05:52 AM
