B16 Block and B20 head?
Old Dec 28, 2002 | 04:42 PM
Blaze45's Avatar
Brrraaaap!
Default B16 Block and B20 head?
I see b16 blocks around everywhere. I also see B20 and LS heads around as well. Would the head fit up to the block? The only reason why I'd like to know is because it would make a good temp. motor if you blew your current one up. What would I have to do to make em fit up? Would I have valve clarence problems and piston clarence problems?
TIA
Blaze
Old Dec 28, 2002 | 04:45 PM
altoid's Avatar
Default Re: B16 Block and B20 head? (Blaze45)
they should bolt right up. Lemme know if you want one. I've got one sitting here, 60 bucks and its yours
Old Dec 28, 2002 | 05:43 PM
Kidnkorner's Avatar
a b16 block and a b20 head? i dont understand, i have seen people doing b20 blcok with b16 head, but not the way you describe.
they will bolt up, but you will have to tap a oil return/supply holes in the block and head or something.
im posting because im curious
Old Dec 28, 2002 | 08:56 PM
Blaze45's Avatar
Brrraaaap!
Default Re: B16 Block and B20 head? (Huggy Bear)
just currious cause I was thinkin of an alternative if one blew his/her engine. This is like an oppistie of a CRVTEC.
thanks
Blaze
[Modified by Blaze45, 5:56 AM 12/29/2002]
Old Dec 28, 2002 | 09:52 PM
spettinger's Avatar
i had the idea to put an ls head on an extra B16 bottom end i had, bad idea. i thought about it once, laughed, and that was the end of that. the ls head would directly line up with the B16 block, but the oiling passages would line up completely wrong. motors are built to be upgraded, not downgraded. i know the B16 block would be pissed that it "has this shitbox cylinder head on top that won't rev past 7 arrrrghhh!" haha.
Old Dec 29, 2002 | 11:24 AM
Diablo Tejano's Avatar
Default Re: B16 Block and B20 head? (2ndhandCRX)
When you were thinking about this had you damaged your VTEC head?
I wouldn't even consider this swap unless my head was significantly damaged or removed for P&P new valves etc, in which case I think this is a viable option.
So you're saying that the coolant and oil passages won't line up on a B16 block w/ LS head, but will on a LS block w/ a VTEC head? Perhaps you would care to elaborate?
While i agree that from a performance oriented standpoint it seems illogical, but if you have a spare B20B or B18B head laying around and for whatever reason your B16 head is out of commission I think its a good idea... temporarily.
James
Old Dec 29, 2002 | 11:42 AM
OBD1 Kenobi's Avatar
We were thinking of doing that with the leftover parts of an LS-VTEC and CR-VTEC head swap. Use the old non-VTEC head on the unused B16A block since to do these you generally can't just buy the B18A/B/B20B/Z block and B16A head on their own. The leftovers would be useful. I have no idea what output one would expect but it should be better than any SOHC.
Old Dec 29, 2002 | 03:34 PM
EFing8's Avatar
Default Re: B16 Block and B20 head? (OBD1 Kenobi)
In theory what you would have there would be the same as a ZC. a 1.6 DOHC non-vtec motor.
mia305sk8a
Sep 20, 2010 05:13 PM
b18hondahb
Oct 26, 2006 05:55 AM
bframe
Mar 7, 2003 10:40 PM
