'92 ls Intermediate shaft work in a '95 Integra?
Old Dec 28, 2002 | 04:29 PM
specie's Avatar
Default '92 ls Intermediate shaft work in a '95 Integra?
I checked at a-autmotiveparts.com and it says they're different part numbers. I was just trying to make sure since I have a '92 LS intermediate shaft. Will it work in a '95 Integra GSR with a ls motor and b16 tranny? Thanks for any info.
Old Dec 28, 2002 | 05:27 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: '92 ls Intermediate shaft work in a '95 Integra? (specie)
Well. the part numbers are definately diffferent...The 94-01 Integra Intermediate shafts have a MALE intermediate shaft on the drivers side....The year of your Teg has a FEMALE intermediate shaft on the drivers side, what u would do is run a 94-01 integra passenger side axle, and a 92 intermediate shaft with a 92 integra drivers side axle (i think).... good luck..
Old Dec 29, 2002 | 01:00 PM
specie's Avatar
Default Re: '92 ls Intermediate shaft work in a '95 Integra? (SIXTYdashONE)
Are the lengths the same? If so, I'll go to the auto parts store tomorrow and pick one up. Thanks.
Old Dec 29, 2002 | 08:31 PM
madtownhonda's Avatar
If you have a 92 LS intermediate shaft, then you need the 90-93 integra axle. If you have a 95 intermediate shaft, you need a 94-01 axle. Simple as that. As long as you have them matched up, they will work fine and they are the same length.
Old Dec 30, 2002 | 05:28 PM
specie's Avatar
Default Re: '92 ls Intermediate shaft work in a '95 Integra? (madtownhonda)
Thank you guys.
Old Dec 30, 2002 | 07:32 PM
sic2kSi's Avatar
Just out of curiousity. What made you put a 92' LS motor in a 95' GSR.
Old Dec 30, 2002 | 08:20 PM
specie's Avatar
Default Re: '92 ls Intermediate shaft work in a '95 Integra? (juz1badLS)
Actually, I was going to put a '92 LS swap (replace pistons and bearings) into my '95 GSR because I found a good deal for the swap. I traded the tranny off and I'm using the wiring harness, injectors, and ecu. I just bought a '95 LS longblock so I'm stuffing that in the car now without a rebuild.
I'm going to rebuild the '92 longblock with forged pistons and swap it in when the '95 LS motor blows.
Now, if you're curious as to why I have a LS motor in a GSR shell, I bought the car w/o drivetrain and I can't afford nor want to put in a GSR swap (too much $$$).
Old Dec 31, 2002 | 09:08 AM
CHEETAH's Avatar
yes ... also dont forget to match up the inner axle seal on the tranny
greg
Old Dec 31, 2002 | 09:52 AM
sic2kSi's Avatar
I thought that was probably the case. Well, if your LS motor comes up missing stock parts, let me know. I have lots.
TTatro
Mar 28, 2019 03:40 PM
red beast
Dec 15, 2006 07:14 PM
EG*MonKEY
Nov 19, 2003 05:16 PM
hatchii
Oct 22, 2003 08:23 AM
