problem w/rpms's bouncing when in park
Old Dec 28, 2002 | 12:03 PM
joeyd's Avatar
Default problem w/rpms's bouncing when in park
my cars a 91 accord at...when my car is warmed up the rpm's bounce from say 1000 to 1500 back and forth...the car runs fine when driving..any ideas what the prob is???thanks
Old Dec 28, 2002 | 01:37 PM
preluder's Avatar
Default Re: problem w/rpms's bouncing when in park (joeyd)
id check for ignition problems or the tyranny fluid or perhaps a vacuum leak any hoses loose or holes in them?
Old Dec 28, 2002 | 02:08 PM
RotaryBzzz's Avatar
is the bouncing fast or intermittant? Does is idle like you've got a cam or does it seem to "get stuck" at 1500rpm and then kick down to 1000rpm after awhile?
Old Dec 29, 2002 | 01:36 PM
Familycarfromhell's Avatar
check your TP sensor
Old Dec 29, 2002 | 02:07 PM
joeyd's Avatar
Default Re: problem w/rpms's bouncing when in park (RotaryBzzz)
theres no pause it just keeps bouncing but it only does this when the car is warm
Old Dec 29, 2002 | 02:40 PM
if it were a vacum problem it would idle at higer rpm's with out giving it gas.
you could check your PC valve that runs on top of your valve cover to intake manafold if it dose not click when you move it up and down that means it's stuck
but you would burn oil also so that would be a give a way.
check your resistor box,plugs,timing, speed sensor. it dosent sound like any thing major. i'm willing to bet a 100$ it's a tp sensor.
good luck,
need parts? i got a boat load of accord parts, find your problem may be i can help you out.
Old Dec 29, 2002 | 06:06 PM
joeyd's Avatar
Default Re: problem w/rpms's bouncing when in park (Familycarfromhell)
thanks alot for the info...ill bring it to my mechanic to find out the prob..and if i do need parts...you'll be the first i ask....thanks again....ill get back to ya
Old Dec 29, 2002 | 06:41 PM
SOHCArchangel's Avatar
bad FIV
remove it and plug the holes or replace it
Old Jan 3, 2003 | 11:07 PM
4thaccord.20m.com's Avatar
i have the same problem so try changing ur IAC valve if not its ur TPS just use a multimeter and go by the book to see if these sensors are bad if not i have no idea right now
mannyquestions9
Sep 29, 2024 09:15 AM
Metal Head
May 31, 2006 10:59 AM
wkdalpha
Feb 15, 2006 08:55 PM
accord115
Jun 23, 2004 06:42 AM
DreamSpeed
May 26, 2002 01:00 PM
