Vaccume leak i think? back me up
Old Dec 28, 2002 | 11:48 AM
hybridb18's Avatar
Default Vaccume leak i think? back me up
does this sound like a vaccume leak, revs from like 2000 to like 800 rpm while at idle. it is a 96 ls motor, and i just swapped the intake mani for one off a 95 ls. i used a mr gasket intake mani gasket, and reused the gasket on the throttlebody. i have changed out the FITV and the IACV, still does the same thing. It idled fine before i changed the manifold.. I also put a different TB off a 95 on it since it has another vaccume port on it fot the charcole canister. When it idles up and down, it goes from like 14 psi of vaccume to 17-18psi of vaccume. im pretty sure this is a gasket leak, but i just need someone to verify my thoughts. I know i can spray come brake cleaner at the gaskets to find the leak, but i dont have any right now, and im stuck at the house because dumb family is here. thanks for any imput
Old Dec 28, 2002 | 01:45 PM
hybridb18's Avatar
Default Re: Vaccume leak i think? back me up (hybridb18)
Also, i just remembered, i changed all the stock sensors from the 96 manifold except for the IAT. Would that sensor cause it to idle like that??? its not throwin any codes, so i dont think its the problem. I also swapped the TPS sensor over, correct me if im wrong but its supposed to be .5 volts at closed thorottle, and 4.5 volts at WOT. One other thing, i have the 95 manifold ported out to accept a 64mm thorottle body, would that cause the problem??? i only have the stock 60mm on there right now though.
Old Dec 28, 2002 | 02:14 PM
hybridb18's Avatar
dont u hate asking questions that u know noone is going to respond to.
Old Dec 28, 2002 | 03:37 PM
SuperSH's Avatar
Spray some carb cleaner near the suspect gasket and see if it speeds up (with the engine running) if it does then you have a leak. I dident know you could swap TPS sensors since they were calibrated to the thorttle body. Maby thats just other cars.
Old Dec 28, 2002 | 04:30 PM
hybridb18's Avatar
Default Re: Vaccume leak i think? back me up (SuperSH)
ok, i found the problem, u cant use a 96 ls tb gasket on a 95 ls manifold. The 95 has the FITV on the bottom of the throttlebody, but the 96 doesnt. So, the 96 gasket was like a 1/4 inch short at the bottom, and air was leaking there. Made a gasket out of a folder, and put it on and runs perfect now. I know, the gasket is kinda bootleg, but it works.
singlecammin
Jan 20, 2011 07:20 PM
Morasso
Feb 3, 2008 10:00 AM
SimplyTron
Jan 26, 2006 08:19 PM
FastNFurious
Aug 10, 2003 06:31 PM
ULTRA911
Mar 4, 2003 10:00 AM
