OEM lip install - I must be an idiot
Old Dec 28, 2002 | 10:57 AM
Thirty-Nine's Avatar
Default OEM lip install - I must be an idiot
Yes, this should be extremely simple. THe only problem is that I can't seem to figure out how to attach the sides! All of the clips are the same (they all have an F on them) but they don't fit in the side holes. Should there be separate clips for those side holes or am I not doing something right?
Old Dec 28, 2002 | 11:10 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: OEM lip install - I must be an idiot (Sushiboy)
what car is this for?
Old Dec 28, 2002 | 11:11 AM
DUH my bad - 98 Civic
Old Dec 28, 2002 | 11:22 AM
-Gambit-'s Avatar
the little "u" shaped clips go on the underside of the bumper with the little nut side facing up. You should have little square shaped cut outs on the buttom side of the bumper which they clip into. Then you get your lip and screw it to the clips with the provided hardware. Hope that help.
Old Dec 28, 2002 | 11:52 AM
Daniel's Avatar
they should fit. at first i thought mine didn't, either (97 civic), but you have to fiddle with them a bit.
Old Dec 28, 2002 | 11:58 AM
Default Re: OEM lip install - I must be an idiot (Daniel)
The front parts were cake, but the side ones are still giving me a bit of trouble. The side cutouts aren't the same shape as the ones in the front, so those clips won't slide in. I just got back from the hardware store and picked up some new bolts, nuts, and a couple of washers, so that should be fine. Thanks for all your help!
97BB6Type-SH
Sep 8, 2006 05:30 PM
Beeline
12
Aug 31, 2006 11:21 AM
LSeeper
Jul 25, 2004 05:28 PM
2000GSR
Mar 19, 2003 07:23 AM
hadookn
May 17, 2002 09:33 AM
