help with my LS MC/booster
I have a '91 integra LS brake MC/Booster that i want to adapt into my '91 civic DX. My problem is, the MC/booster i got is for ABS. One of the fittings is a different size (bigger) from what is in my car. Can I get a reducer for it to adapt to my car? Any suggestions? Has anyone else run into this?
i run a non abs master cylinder, i would suggest you do the same. buy a new one as a last resort, i think they run around $50 from a parts store. try autozone before napa if you want to save some cash.
Okay, will my brake booster i got with the MC work with a non ABS MC? otherwise im lookin at rebuying what i already bought, and having to scour the junkyards for the parts cause a new booster is $$$. Thanks!
yes it will work.My friend is currently doing the same thing.You have to get a tool, to flare the end of one of the lines to make it fit which is tricky but can be done, I watched it happen, and if you use it, the abs MC, you get the 1" instead 15/16"
so it is a good upgrade if you think you have the skills.
Suspension & Brakes
Aug 17, 2012 06:45 AM
Another Drew
Jul 4, 2005 06:35 PM
