Spoon ECU vs. Spoon Spec ECU
Old Dec 27, 2002 | 04:53 PM
chigsu's Avatar
Default Spoon ECU vs. Spoon Spec ECU
i was just wondering if any could tell me the difference between the JDM Spoon ECU for CRX SiR and a PR3 ECU with Spoon Spec Chip installed. is there any performance differences? bec the prices seem very different. thanks!
Old Dec 27, 2002 | 05:10 PM
ezark's Avatar
Default Re: Spoon ECU vs. Spoon Spec ECU (chigsu)
Spoon ' Spec ' is simply a knock off...most of the time, the actual program is simply replicated.
Old Dec 27, 2002 | 05:58 PM
chigsu's Avatar
Default Re: Spoon ECU vs. Spoon Spec ECU (gsR-T mode)
i guess the better question now is, which one would u buy? assuming ur not some major bling bling baller loaded to the max
Old Dec 27, 2002 | 09:27 PM
spettinger's Avatar
there are people out there that will spend the cash in order to say they have a
"sPoON ECu, yO!" there are people that buy the spoon ecu for their function and quality, especially over ecu chips. would i buy a chip? sure, i would rather only run one O2 sensor, and raise the rev limit to handle the revs my motor will be capable of. i would not look to a chip to play with ignition or fuel curves, would rather have an ITC and VAFC.
Old Dec 27, 2002 | 09:31 PM
Frosty_spl's Avatar
Default Re: Spoon ECU vs. Spoon Spec ECU (2ndhandCRX)
i have a spoon program ecu. 1 o2 sensor, 4500 vtec point, increased fuel etc. REAL spoon ecus are a waste of money, if you can find one that is. I would rather run a hondata for the same price.
My spoon programmed ecu is the exact same thing as a REAL one.
Old Dec 27, 2002 | 10:08 PM
spettinger's Avatar
Default Re: Spoon ECU vs. Spoon Spec ECU (Frosty_SPL)
"my spoon chip is the same thing as the spoon ecu."
i don't buy that for a second. i am sure the spoon ecu offers adjustments in fuel, ignition, and vtec crossover, etc. i would rather have the hondata as well, just saying that it would be very hard to get an accurate tune from just an ecu chip, which would need to be optimized to your settings/parts.
Old Dec 27, 2002 | 10:29 PM
Frosty_spl's Avatar
Well, it might not be the exact same, but it gets the job done.
exactly. Neither does a REAL spoon ecu
[Modified by Frosty_SPL, 11:36 PM 12/27/2002]
zrickety
Jan 27, 2009 12:12 PM
jdm-hondacura
Dec 6, 2006 01:30 PM
BillB
Jan 6, 2005 02:46 PM
JdmEg6Hybrid
Mar 26, 2004 11:36 AM
acteg94
Jun 14, 2002 12:55 PM
