Measuring camber
Old Dec 27, 2002 | 01:48 PM
uNF$@#!'s Avatar
Default easuring camber
anyone have a good way to measure the amount of camber a wheel may have? ...or if there are places that can do this for you (incase expensive equipment is required).
I know you can probably do a eye thing, but i dont think that would be very accurate.
we just installed springs on a wrx and cant figure out which camber kit to get him....
Old Dec 27, 2002 | 01:52 PM
Chris N's Avatar
Default Re: easuring camber (Soup ****)
Wai has a very neat guage that measures camber. He showed it off at Gingerman in october. It's basically an electronic gauge attached to a triangular shaped piece, the three ends get placed up to the wheel and it measures the angle, after you calibrate it with the ground/surface near the tire/wheel.
Hopefully he sees this and has more exact info. Neat, accurate device.
[Modified by Chris N, 4:52 PM 12/27/2002]
Old Dec 27, 2002 | 01:53 PM
Mugen Mike's Avatar
You mean other than on an alignment rack?
Old Dec 27, 2002 | 01:54 PM
sgT's Avatar
sgT
Default Re: easuring camber (MugenMike)
yep. get a camber gauge
Old Dec 27, 2002 | 01:55 PM
Chris N's Avatar
Default Re: easuring camber (sgT)
So Wai has a camber gauge. [edit]which is what i was describing...[/edit]
[Modified by Chris N, 4:57 PM 12/27/2002]
Old Dec 27, 2002 | 01:59 PM
Mugen Mike's Avatar
Default Re: easuring camber (Chris N)
~$200-250 at http://www.racerpartswholesale.com/
Old Dec 27, 2002 | 02:01 PM
Chris N's Avatar
Looks familiar.
Old Dec 27, 2002 | 02:08 PM
Mugen Mike's Avatar
There's also the "bubble guage" style
Only around ~$140
Old Dec 27, 2002 | 02:20 PM
sgT's Avatar
sgT
mine cost me 30 bucks i think.
Old Dec 27, 2002 | 03:04 PM
Mugen Mike's Avatar
Where?
Old Dec 27, 2002 | 03:40 PM
IGGY's Avatar
If you don't want to spend a lot of money and you have a one of those bubble level things. Go to a place that you know the ground is level, find a board, and put both upagainst the rim. then you can adjust with camber.
Old Dec 27, 2002 | 06:53 PM
rainmanEK's Avatar
big strong guy
Thats what I had/used on the race car!
Works great, Though level ground is a must!!
An angle guage (cheap) and bubble level could also do trick!
eric
Old Dec 27, 2002 | 07:09 PM
uNF$@#!'s Avatar
Default Re: easuring camber (rainmanEK)
angle gauge wouldnt do it...so i think....b/c it would not be measuing the proper angle (perpendicular to surface).
if i adjust the toe on the vehicle, then adjust the camber, will the toe come out of spec again?
TIA
Old Dec 27, 2002 | 08:47 PM
Wai's Avatar
Wai
ProFunction/GT Motoring
This is what I have. But the one shown in the pic is for go-kart. The one for cars is bigger. The best part is that electronic module. It can be calibrated to accommodate unlevel floor. A bubble gauge would cost a lot less.
I spent like $250 for this thing but I figured that a year before I brought the car to a shop to have the alignment done twice, $110 a pop. So I guess this piece is worthy, especially I'm raising and lowering the car for different setups couple times a year.
[Modified by Wai, 11:48 PM 12/27/2002]
Old Dec 28, 2002 | 01:34 PM
Petah's Avatar
Default Re: easuring camber (Wai)
Can this do toe as well?? Or just Camber?
Old Dec 29, 2002 | 10:38 PM
DC2ITR's Avatar
Default Re: easuring camber (eg-six)
i'm wondering the same??
Old Dec 30, 2002 | 01:47 AM
Phoenix_ITR's Avatar
Default Re: easuring camber (DC2ITR)
these gauges just read camber. your best bet for toe would be a set of toe plates and a couple of tape measures.
Old Dec 30, 2002 | 05:21 PM
Louie's Avatar
What would Chente do?
Yes, if you adjust toe then camber, your toe wil be out of spec again.
Always adjust camber/caster first, then toe. hth.
th34nt0ni0
Suspension & Brakes
Dec 21, 2008 02:15 PM
Kyles ej1
26
Nov 19, 2004 06:09 AM
Bills01ITR445
Oct 15, 2002 12:07 PM
AdamITR
Jun 24, 2002 03:13 PM
