D Series Power::Crane Stage 2 Cam for D16A6 DONE!!
Old Dec 27, 2002 | 01:12 PM
slowman's Avatar
I took way too long
Default D Series Power::Crane Stage 2 Cam for D16A6 DONE!!
Allrite fellas, got it in. Haven't taken it down the road or anything yet but will soon. Got the lash corrected and it's good to go. The pics will be up tonite on my website: http://www.geocities.com/slowmanef/intro.html. The COMPLETE write up of it can be found: http://www.geocities.com/slowmanef/d16a6cam.html Thanks to EVERYONE on here who helped me. Idles allrite just when I rev it, and the rpms fall, it sometimes quits. I'll take it up the road though and see how it is. The write up will be finished by tonite. Thanks again
Old Dec 27, 2002 | 03:16 PM
slowman's Avatar
I took way too long
Default Re: D Series Power::Crane Stage 2 Cam for D16A6 DONE!! (Optiks)
just got back from the first test drive. drives real nice and has A LOT meaner exhaust note!! everything seems fine. no flooring it though, gotta let it break in. but i got it going a lil and it sure felt good! later
[Modified by slowmanEF, 7:17 PM 12/27/2002]
my_slow_civic's Avatar
Default Re: D Series Power::Crane Stage 2 Cam for D16A6 DONE!! (slowmanEF)
I'm sure you know this already. But you may want to let it break in a bit before you go tearing off down the road.
Old Dec 27, 2002 | 03:18 PM
slowman's Avatar
I took way too long
Default Re: D Series Power::Crane Stage 2 Cam for D16A6 DONE!! (sirk)
yeah i dont wanna screw up all the work i just did.
Old Dec 27, 2002 | 05:58 PM
Creepshow S60's Avatar
nice site. i was reading about the camshaft install and then came to a page on it that wasn't availible for some reason. fix it dammit!
Old Dec 27, 2002 | 06:02 PM
slowman's Avatar
I took way too long
Default Re: D Series Power::Crane Stage 2 Cam for D16A6 DONE!! (y-49CRX)
to fix it, i have to pay money which i might eventually do if peeps starting visiting the site and it actually has a purpose. haha.
Old Dec 27, 2002 | 06:09 PM
1.8Tities's Avatar
I can't wait for you tell us how it performs.. *Go team crane* hahahahaha
Old Dec 28, 2002 | 06:05 AM
Jared's Avatar
nope, go beat up on it. there is no break in for a camshaft install. btw, if the lobes are big enough, you may need to set your idle up to get a firmer idle.
Old Dec 28, 2002 | 06:54 AM
Superhatch's Avatar
Default Re: D Series Power::Crane Stage 2 Cam for D16A6 DONE!! (Jared)
Nice write-up! Cant wait for the final results...if its good I just might get one for myself
-Jake
Old Dec 28, 2002 | 07:40 AM
EG8R's Avatar
Default Re: D Series Power::Crane Stage 2 Cam for D16A6 DONE!! (SuperHatch)
I just noticed something.... Wheres the Skunk2 cam gear?
Old Dec 28, 2002 | 02:13 PM
[626]95-GSR's Avatar
Default Re: D Series Power::Crane Stage 2 Cam for D16A6 DONE!! (madeiniraq)
Theres no need to for a "break in" period for a cam install. All the components should be properly lubed upon start-up. When i have installed cams, i would let it idle a bit.. listen for any sign of valve tap.. then mash the gas pedal.
One thing i noticed upon reviewing your cam install, is the valve adjusting process. The engine should be "Cold" (100F) when adjusting valves. Other than that, its all good. Now get on the gas.
And just like Jared said.. you will have to set your idle higher. Itll be fine for cooler situations, but once the engine is warm.. it will want to stall. Summer time is the worst. Just raise your idle up a little.
[Modified by [626]Rj-SiHatchy, 3:16 PM 12/28/2002]
Old Dec 28, 2002 | 02:48 PM
Stupid Ass's Avatar
Default Re: D Series Power::Crane Stage 2 Cam for D16A6 DONE!! ([626]Rj-SiHatchy)
The guy he bought the gear from didnt send him a part... so he is trying to get the part and then he can put the Skunk gear on.
Old Dec 28, 2002 | 05:32 PM
slowman's Avatar
I took way too long
Default Re: D Series Power::Crane Stage 2 Cam for D16A6 DONE!! (-= UnKoiled =-)
Yeah, thats right. The tooth on the gear didnt come. Anyone know where to get this piece? Ok, so no break in? Good. Im getting ready to go out and floor it to feel the power! And what do you want vids of? I can take some...
Old Dec 28, 2002 | 05:35 PM
slowman's Avatar
I took way too long
And the crane cam card said it should be hot. But i have a haynes manual and it said cold.... i didnt know so i just went with what crane said.
Old Dec 28, 2002 | 09:27 PM
D-Man's Avatar
There is a break in for a new cam,you suppose to rev it too 2000-2500 rpm for like 20 mins as soon as you start it so it gets enuff oil and the lobes wear in but if you already drove it,forget it....beat on it.
Old Dec 28, 2002 | 09:41 PM
slowman's Avatar
I took way too long
Default Re: D Series Power::Crane Stage 2 Cam for D16A6 DONE!! (D-Man)
floored it. top end ownz
Old Dec 28, 2002 | 09:43 PM
Stupid Ass's Avatar
Its about time you got a little quick... good boy Johnny...
Old Dec 29, 2002 | 07:50 AM
slowman's Avatar
I took way too long
Yeah, bring your car up here and lets race!
As long as my dads available
Old Dec 29, 2002 | 09:46 AM
Superhatch's Avatar
Thats all you got for us???!!! How about a little detail? or...*cough* a vid
-Jake
Old Dec 29, 2002 | 10:01 AM
slowman's Avatar
I took way too long
a vid will come sometime. but lemme tell you, it pulls pretty good. i shifted into second normally and then floored it. bam! at redline before i knew it. third, still climbing the revs as good as in 2nd. it's definatly a wicked cam!
Old Dec 29, 2002 | 10:44 AM
Broken Gearbox's Avatar
Will these cam effect your gas mileage by alot or what??
Old Dec 29, 2002 | 10:59 AM
EG8R's Avatar
Default Re: D Series Power::Crane Stage 2 Cam for D16A6 DONE!! (x lP lL i c i t)
Yes because you want to floor it more often lol
Old Dec 29, 2002 | 11:10 AM
Default Re: D Series Power::Crane Stage 2 Cam for D16A6 DONE!! (mr. skelly)
lol....true
Old Dec 29, 2002 | 11:34 AM
Jared's Avatar
Probably not. I have a friend with an 89 DX with a built B18A. JG 301x cams, 10.5:1 c/r, ported head, DC header, intake pipe, 2.5" exhaust. It runs in the 13s all motor on street tires and has seen 12.9 on a 105 shot of juice on BFGs. We drove that car to dinwiddie last year for the battle of the imports(we're about 5 hours away) and it got 38mpg both ways. Show me a V8 that can do that.
Old Dec 29, 2002 | 11:36 AM
slowman's Avatar
I took way too long
lmao
