HELP!!!!!!!!!!Stock Fuel Filter Fittings!!!!!!!!!!
What fitting do I need to use to connect a steel braided line to my stock fuel filter?
Last night my friend tapped my stock filter, and picked up some pipe fitting from Home Depot to connect a steel braided line from the fuel rail to the stock filter. The damn thing kept leaking fuel from where we tapped. Yes we used teflon!
I know there must be an easier way! I am going to buy another stock filter, so what I need to find out is:
WHAT FITTING DO I NEED TO BUY TO PUT IN MY STOCK FILTER SO A STEEL BRAIDED LINE CAN BE CONNECTED TO IT? Also, I am using a size 6 line.
Thank You.
Thank You.
I was just wondering which angle is the best, 120, 150, or 180 ? I personally have the 180 becuz I read this thread long ago, but I think Flamenco-T is selling his with a 150 degree one now.
I really doubt home depot will have a -6AN adapter. You need metric to JIC (-6AN) 37 deg flare male to male adapter then you can screw in the hose end and the line.
I used 150 degree hose ends on all of my customer's fuel line kit...
Some example,
Let me know if you need the adapter, I litterally have about 500 -700 fittings inventory..
stan
Some example,
stan
2-7offsuit
May 25, 2006 01:38 PM
turbo Si
Dec 27, 2002 01:27 PM
