HELP!!!!!!!!! Stock Fuel Filter Fitting!!!!!
Old Dec 27, 2002 | 12:14 PM
turbo Si's Avatar
Default HELP!!!!!!!!! Stock Fuel Filter Fitting!!!!!
What fitting do I need to use to connect a steel braided line to my stock fuel filter?
Last night my friend tapped my stock filter, and picked up some pipe fitting from Home Depot to connect a steel braided line from the fuel rail to the stock filter. The damn thing kept leaking fuel from where we tapped. Yes we used teflon!
I know there must be an easier way! I am going to buy another stock filter, so what I need to find out is:
WHAT FITTING DO I NEED TO BUY TO PUT IN MY STOCK FILTER SO A STEEL BRAIDED LINE CAN BE CONNECTED TO IT? Also, I am using a size 6 line.
Thank You.
Old Dec 27, 2002 | 12:26 PM
sgT's Avatar
sgT
Default Re: HELP!!!!!!!!! Stock Fuel Filter Fitting!!!!! (turbo Si)
try teflon paste
Old Dec 27, 2002 | 12:32 PM
turbo Si's Avatar
Default Re: HELP!!!!!!!!! Stock Fuel Filter Fitting!!!!! (sgT)
Too late, we stripped the thread last night trying to tighten and stop the leak.
Old Dec 27, 2002 | 12:38 PM
B18EG6's Avatar
haha....here you go...again
-6 to 12mm x 1.25 EAR-991945
Old Dec 27, 2002 | 12:44 PM
turbo Si's Avatar
Default Re: HELP!!!!!!!!! Stock Fuel Filter Fitting!!!!! (B18EG6)
Damn.....you move quick!
Is that an Earls Fitting part number?
If so, that will screw into the stock filter without any tapping?
_______
powerdbygarrett
Jun 22, 2007 08:50 AM
dustin
Aug 4, 2004 12:40 PM
IntegraXTR
Jan 25, 2004 07:13 PM
turbo Si
Nov 26, 2003 09:59 PM
turbo Si
Dec 27, 2002 01:27 PM
