ATTN: Turbo sohc people, how much boost?
Im planning on having my block sleeved and throwing some sorta semi low comp pistons/rods and boosting. How much boost are you guys running with your turbo setup's and what kind of block work do u have done? What kind of fuel setup are u running? Thanx in advance
chris
btw its a d16y7
chris
btw its a d16y7
first its more about engine management then how well the engine is built.. it has a lot to do with it but if you run standalone fuel management it is much better.. i am running the stackable headgasket from mr. gasket and i am about 8.5:1 compression.. i am only running 7lbs at the moment i will upgrade later but i just blew one motor so i went safe and lowed the compression and dynoed tuned mine so that way i am ok for daily driver..
yea i was thinking 10-12 daily and i wanted to do around 20+ at the track.
...using the hondata 3b with 500+ cc injectors...what do u guys think?
What do you have for the turbo set up now...I'm guessing this is a built-yourself set up? I've been looking for a good turbo kit for a sohc non-vtec. Having experience what would you recommend
Stock D16 rods are good up to about 225-230WHP...depending on NUMEROUS factors...timming, colder plugs..tuning...ect..
you your block is built w/ standalone....i'd run 1 bar daily and even more when i need it
If it's gonna be built you can easily run 20psi at the strip.
if you do plan on running that high of a boost level I suggest you get bigger injectors, but that's just my opinion.
ex. hondata & 720's should take care of all your management IMO.
!MUY IMPORTANTE!
Get a good tune and all should be well.
!MUY IMPORTANTE!
boostedsohc91hb
14
Feb 13, 2004 09:13 PM
