tranny for R in EF
a mnef9 my buddy is using his s1 b16 tranny with 93 teg axles, stay cable that hydro **** is a mess i know my buddy tried it.
nice ride mn i like the clean under construction look
[Modified by 1991_jdm_sleeper, 9:26 PM 12/27/2002]
if you are mechanically inclined (read, good with tools and fabrication) then you can make any B series Hydro tranny fit the type r engine in the EF.
I've done it three times.
Do a search, it's has been covered here quite a few times already.
Has anyone ever considered using a tilton clutch pedal assembley for this...they can be bought with the master cylinder an I would assume it would be much easier to do then to put in a stock hydro system.
quaife doesn't make an LSD for the JDM trannies.. different bearings, i believe.. trust me. i've been through that before.. you'll have to go Kaaz, or possibly cusco.
as far as the tranny goes, the J1 is great because it is most like a stock type R tranny, just a cable-spec! the only thing that's different, is 5th gear is higher, but final drive is lower..
DNRxperformance
Northern California (Sales)
May 5, 2007 09:54 AM
