increasing displacement on a B18C
Old Dec 27, 2002 | 10:22 AM
hypa's Avatar
Default increasing displacement on a B18C
If I went with 84mm sleeves, and 84mm pistons, could I effectively increase my displacement to 1.9L (as per C-speed calculation)?
Is there anything else needed in this, or is it as simple as buying sleeves and pistons?
Also, when you resleeve a block with a set of darton (or GE) closed deck sleeves, is it possible to retain the factory oil squirters?
Thanks for the info.
I've built toyota and chevy motors before, but this will be my first Honda (and it's my own )
Old Dec 27, 2002 | 11:56 AM
sgT's Avatar
sgT
Default Re: increasing displacement on a B18C (hypa)
thats pretty much it.
you retain the oil jets.
rods might be a good idea. but not necessary
Old Dec 27, 2002 | 01:13 PM
CHEETAH's Avatar
the cheapest way to get a *1.9L* B-series motor is to bore an LS out to 81.5mm ... don;t have to go 84mm with the GSR
"chevy motors" no wonder your first mod is increasing displacement ... heh
Greg
Old Dec 27, 2002 | 06:38 PM
allmotorhonda's Avatar
Default Re: increasing displacement on a B18C (CHEETAH)
or use a B18C block bored to 81.5mm and use an LS/CRV crank, that way you get to keep the oil squirters and crank girdle
Old Dec 28, 2002 | 07:45 AM
hypa's Avatar
I'm off to seperate the head from the block now.
ics to come soon.
90CB7EX
Oct 22, 2016 12:33 AM
kgreenhaw
Aug 3, 2012 12:24 AM
q8delsol
Nov 13, 2007 05:09 PM
v4lu3s
Apr 18, 2006 12:48 PM
PowerHouse
Nov 8, 2004 05:43 PM
