ANOTHER throttle body question.
Old Dec 27, 2002 | 10:02 AM
ex voto's Avatar
Default ANOTHER throttle body question.
Well... I got the throttle body back and all is good. We ended up using a Corvette TB blade and modified it a bit to work... seems to work pretty well.
The blade, however, has a little gap between it and the inner wall of the TB. Not a lot, mind you... but made me wonder anyway. In my experience, since the Hondas don't have an IAC motor mounted on the TB (Idle Air Control) that a little air bleed is OK. Corvettes on the other hand make an airtight seal around the blade... but then again, they have an IAC motor.
Any suggestions? If you'd like, I can e-mail a pic of the TB and show some of the gap.
Thanks in advance.
Old Dec 27, 2002 | 12:56 PM
ex voto's Avatar
Default Re: ANOTHER throttle body question. (ex voto)
*bump*
Just in case someone knows what I'm talking about.
Old Dec 27, 2002 | 03:05 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Hondas do indeed have an idle air control valve. IACV or EACV
it's located right after the T/B behind the manifold.
A bit of gap is no problem unless it lets too much air and it will in efect be a vacuum leak creating idle problems.
if the idle is OK, then don't worry about it.
Old Dec 28, 2002 | 07:04 AM
ex voto's Avatar
Default Re: ANOTHER throttle body question. (Spaceballs the lunch box)
Well, *****. I guess I'm used to the doemstics Chevy and Ford stuff.
There not MUCH bleed, but enough to have me thinking. Guess I'll just install it and see what happens.
magicguy
Jan 30, 2009 02:00 PM
Spool This
10
Aug 3, 2008 01:25 AM
smash fascism
Apr 10, 2005 06:39 AM
Shft@9GSR
Apr 15, 2002 11:47 AM
