What supports your turbo and manifold????
How are you guys supporting the turbo manifold, turbo, and wastegate??? The stock manifold has a bracket that supports the manifold and takes the weight off the head flange.... what are you turbo guys using????
actually that's a good question. i don't have a turbo setup installed yet but i do know the mani/turbo/WG combo is pretty heavy. i'm sure upgraded flange studs help but a support bracket would help also.
Most of the cast mnaifolds, dont have any type of support strap or anything, the manifold is thick enough to with stand the weight...
But on the tubular manifolds, i have seen them with a stap that bolts to something so that it can help support the weight of the turbo....
HTH
Brian
HTH
Brian
you dont really need to support the turbo on most applications. the only time you need to do that is if the manifold hands the turbo out real far creating a moment on the head flange and the welds connecting the runners. echo car supports turbo, laskeys and jotech will support turbo also. if you get just a little rev hard or somethin like that you dont have to support turbo
My T25/STD manifold combo is about 12 lbs heavier than the stock EX manifold from a D16Y8. I was surprised too... I added a nice fat flex pipe to further reduce any possible stress though.
Upgraded flange studs? where do you get these?
Howard
How's this for overhang?
Hey earl how are you guys gonna support the turbo or does the manifold already have a brace coming from the rear to the flange area. My rev hard is similar to your design and has no brace just wondering as well thnx-pdang
This next question is really off topic how on earth did my precentage rating go down. What is it for ....?
[Modified by bambooluv, 8:57 AM 12/31/2002]
