Valve clearance adjustment temperature
Old Dec 27, 2002 | 07:56 AM
4doorH22's Avatar
Default Valve clearance adjustment temperature
The Helms only says "valves should be adjusted only when the cylinder head temperature is less than 100 degrees F." No lower limit is specified. It's 30 degrees right now. Should I adjust the valves with the head at 30 degrees? Should I go for a drive and let the head cool down to ~70 degrees and adjust the valves?
Thanks.
Old Dec 27, 2002 | 08:19 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Valve clearance adjustment temperature (4doorH22)
you'll be fine to do it with them cold like that, they just can't be hot...... if theystill tick, you can always try adjusting them when they are a little warmer
Old Dec 27, 2002 | 08:54 AM
4doorH22's Avatar
Default Re: Valve clearance adjustment temperature (Boosted97Lude)
Oh, thanks, they aren't even noisy, I thought they were just due for inspection. Now I see even under the severe conditions maintenance schedule they don't need to be inspected/adjusted until 105K miles "unless noisy." So I guess I won't touch them at all.
Old Dec 27, 2002 | 02:46 PM
BoostedH23a1's Avatar
cold is fine.
Old Dec 27, 2002 | 03:13 PM
4bidden's Avatar
Default Re: Valve clearance adjustment temperature (BoostedH23a1)
I think the Helms reads <100 degrees. I usually just do it after the car has been sitting over night.
Vtec04
Engine Machining & Assembly
Nov 10, 2017 02:23 PM
SirRevvs
Oct 14, 2010 10:32 AM
HondaKing90
19
Feb 15, 2010 04:38 PM
KiTTeN.MiTTeNs.
Jan 24, 2010 05:45 PM
91_HB
11
Jun 28, 2005 05:41 PM
