???????????????Need a GOOD Intank fuel pump ???????
To fit a Teg/Civic, I have changed so many wallboro pumps and sick of them.
I heard either a RX7 or a Turbo Supra would fit ,
Anybody know for sure which one and which year ??????
Thanks in advance.
[Modified by CRVRX, 4:11 AM 12/27/2002]
Thanks in advance.
That really doesn't help.
I have one sitting in the car right now which is dead, It has been the 5th in 3 years. It runs at 45 psi which really isn't asking too much of it.
There must be something out there better.
John, Thankyou !
What year do I need ? I need one tomorrow. My car is sitting dead needing a tow to my shop so I can fix it. But I aint putting in any more USA made pumps.
Thanks,,,,,, John.
[Modified by CRVRX, 4:19 AM 12/27/2002]
Thanks,,,,,, John.
i would check http://www.supraforums.com but... I can make a few phone calls for you if you would like
. BTW, a stock pump should get you at least running, i have a few if you need one.
Which Walbro pump or pumps did you have before? Because as you can see in the picture, the regular 255 walbro pump (the GSS-315/317 pump) is actually worse than the regular walbro 190 pump because it can't handle anything over 90psi.
[Modified by sak, 9:23 AM 12/27/2002]
I have always used a Gss342. I used to use FMU's and run super high fuel pressure.
This last one has been in there since I went to stand alone and has never seen high pressure.
Thanks for the chart.
jabroni95gsr
Oct 3, 2002 12:58 PM
deacs
Sep 6, 2002 02:17 PM
