can i use oil cooler for oil return line
Old Dec 26, 2002 | 04:14 PM
ziggity's Avatar
Default can i use oil cooler for oil return line
if i get an oil cooler can i tap into it and return the oil back there or will this not work for some reason i have a sh prelude
Old Dec 26, 2002 | 04:28 PM
BoostedH23a1's Avatar
Default Re: can i use oil cooler for oil return line (ziggity)
good question...i would like to know also.. here are my thoughts
i woulnd think the oil would cool all that much cause its such a small feed line running to the turbo but thats just me thinkin off the top of my head..
anyone else..
Old Jan 10, 2003 | 11:45 AM
MugenGTR's Avatar
Default Re: can i use oil cooler for oil return line (BoostedH23a1)
it should work fine, any1 wanna second me?
Old Jan 10, 2003 | 11:56 AM
Smashback's Avatar
Default Re: can i use oil cooler for oil return line (MugenGTR)
No, it won't work. You want pressure to push oil thru a cooler and since there's no pressure coming out of a turbo, it's going to cause the oil to back up in your turbo and your seals will blow on you.
Also, the oil return has to drop below where it comes out of the turbo. The oil cooler should be mounting with the fittings on top or on the side, and if they are on the side, you want the cooler's feed to be the top fitting.
[Modified by Hatchblack, 8:56 PM 1/10/2003]
1997boostedeg
Apr 10, 2012 06:58 AM
revhigh96
Sep 6, 2003 08:19 PM
silverpenny
Apr 28, 2003 06:54 AM
15psi of fun
Feb 4, 2003 10:17 PM
Smashback
Aug 15, 2002 08:44 AM
