wiring pins...searched but nothing..
how do pin the wires(for vtec)to the ecu plug? i was looking at it do i need to get the pins and then pin them...or...
where do i get the pins?
Get to a junkyard and cut off the inside ECU plugs and as much wire as you can. I use a sewing machine needle to remove the pins from the plugs. You could break the plugs open to get them out, but you'll need to learn to repin them when you start adding wires to your stock ECU plugs.
