Gude vs Web ZC cams
Old Dec 26, 2002 | 11:28 AM
APEXI Si's Avatar
Default Gude vs Web ZC cams
I am looking to get some cams for my ZC and I bot web an gude makes cams in my price range..Has anyone used these cams for have had any good or bad results from them.. Any info is usefull
thanks
Old Dec 26, 2002 | 01:42 PM
bottledcrx's Avatar
Default Re: Gude vs Web ZC cams (crx616)
I've got a set of crower regrinds in my zc.. they were cheap to get done. like 137.00 and they have a nice lope at idle and pull hard as hell up to cutoff.. i think there great for the money.. just my 2cents
Old Dec 26, 2002 | 01:43 PM
altoid's Avatar
i personally haven't used any gude products but i constantly hear bad things about his stuff, make sure you do plenty of research and are completely comfortable with your decision. What stage and price range for your cam are you looking at?
Old Dec 26, 2002 | 06:38 PM
APEXI Si's Avatar
Default Re: Gude vs Web ZC cams (altoid)
My price range is like 500 for both cams... interested in just about any thing that makes good power
Old Dec 27, 2002 | 12:48 PM
dtcrx89's Avatar
I've had a Web Cam in my d16a coming on up 80,000 miles. I forget which cam I have, but I believe it's the mild one. The cam idles well and pulls hard after 4300 to redline.
Old Dec 30, 2002 | 09:27 PM
MADEINIRAQ's Avatar
Default Re: Gude vs Web ZC cams (dtcrx89)
could you tell a big difference when you put that cam in?
Old Dec 30, 2002 | 10:33 PM
50shotRex's Avatar
ive had gude cams in my zc, motor revved alot faster
Old Dec 31, 2002 | 11:14 AM
dtcrx89's Avatar
Default Re: Gude vs Web ZC cams (50shotRex)
The difference i noticed right off the bat is that all the I/H/E seems to work together now. With the timing advanced and an AEM timing gear added. The power band was more tuned in and set closer to 4000Rpm versus higher in the power band. You can really feel the torque when you pass 4000 to redline. To me it feels like all the upgrades seem to be working in sink or put to use at an lower rpm band. At least the driver will notice the difference.
White91EF
Jun 1, 2007 12:35 AM
hatchinprogress
Jul 14, 2004 02:11 PM
FBPninetynineEM1
Jan 26, 2003 12:48 AM
tyler
Oct 4, 2002 06:28 AM
zcivic91
Apr 14, 2002 04:31 PM
