Expansion slots. Turbo guys.. Take a peek...
Old Dec 26, 2002 | 07:14 AM
DIY_Racing's Avatar
Default Expansion slots. Turbo guys.. Take a peek...
I will be receiving my turbo manifold very soon. Its identical to this one. I have read about expansion slots on the manifold that will help prevent cracking. I just wanted to make sure that this is where i should make the expansion slots.
See red lines
I figured just run a band saw through it.. that would be sufficient??? Am i on the right track?
[Modified by DIY_Racing, 4:15 PM 12/26/2002]
Old Dec 26, 2002 | 07:37 AM
bryan305's Avatar
Default Re: Expansion slots. Turbo guys.. Take a peek... (DIY_Racing)
Where did you read about these 'expansion slots'?
Old Dec 26, 2002 | 07:41 AM
blufke's Avatar
Default Re: Expansion slots. Turbo guys.. Take a peek... (bryan305)
they are there to relieve some stress from the expansion and contraction when it gets hot and cold. and that is the place i see them when they are on manifolds.
Old Dec 26, 2002 | 07:50 AM
BlueShadow's Avatar
Default Re: Expansion slots. Turbo guys.. Take a peek... (blufke)
Yup one thing that will happen if you dont make expansion slots or if your bolt holes dont account for heat expansion, is as soon as the manifold flange expands it will shear all the bolts off of the block.
Old Dec 26, 2002 | 10:39 AM
racerxadam's Avatar
the problem actually occurs when the runners are made out of a material that expands more rapidly than the material that makes up the flange. In the case of the max rev manifold shown (at least thats what it looks like to me) the manifold's runners are made out of stainless and the flange is made out of mild steel. Stainless expands more rapidly than mild steel. Without the expansion slots the runners would be putting stress on the flange and cause it to warp when it gets hot.
Pretty sure thats the logic behind it. The manifold builders on here should comment on it too.
I decided to cut them in my manifold, I figured they can't hurt. I think a bandsaw would do the job just fine, and yes you marked them in the right spot
[Modified by racerxadam, 2:41 PM 12/26/2002]
Old Dec 26, 2002 | 03:52 PM
earl's Avatar
Default Re: Expansion slots. Turbo guys.. Take a peek... (racerxadam)
FFGeoff put them in our manifold that he did for us.
Old Dec 26, 2002 | 04:03 PM
PrecisionH23a's Avatar
Default Re: Expansion slots. Turbo guys.. Take a peek... (earl)
My drag gen 2 has that also.
Old Dec 26, 2002 | 07:43 PM
TurbothisLS's Avatar
Default Re: Expansion slots. Turbo guys.. Take a peek... (GudeH23a)
my maxrev has them
Old Dec 26, 2002 | 09:04 PM
Full-Race Javier's Avatar
right, those are the correct locations and a bandsaw works just fine. u may have to surface the flange after its cut. sometimes when the runners are welded to the flange, the heat can warp/distort/stress it. during and after the cut the flange trys to return to its original position and the runners can become uneven. this only really happens when there are gaps that are filled between the flange and the runner. or u could just cut the slots around the bolt holes
[Modified by javierb14, 10:26 PM 12/26/2002]
Old Dec 26, 2002 | 09:12 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Expansion slots. Turbo guys.. Take a peek... (javierb14)
Here I found a better pic:
Old Dec 26, 2002 | 09:53 PM
lilxvtecxpwr's Avatar
Default Re: Expansion slots. Turbo guys.. Take a peek... (Arturbo)
thanks for stealing my picture
Old Dec 26, 2002 | 09:57 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Expansion slots. Turbo guys.. Take a peek... (lilxvtecxpwr)
uhh, I took that pic in vegas..hehe
Old Dec 26, 2002 | 10:29 PM
hehe, i carried that thing all over vegas
Old Dec 26, 2002 | 11:45 PM
i was talking about the maxrev manifold up top. they guy that posted this thread jacked my photo.
[Modified by lilxvtecxpwr, 2:46 AM 12/27/2002]
Old Dec 27, 2002 | 06:10 AM
DIY_Racing's Avatar
Ok, so there should be three slots then?? all the way through.?? Or should i just slot the holes for the head only???
Getting mixed answers.. SOme say to cut where i drew, and some say to cut just the bolt holes.....
any more help??
And you have to be kidding me about the picture LILXVTECXPWR. If your gonna cry about me using your picture ill remove it.
Old Dec 27, 2002 | 06:34 AM
BoostedH23a1's Avatar
where the hell are they on that mani..
Old Dec 27, 2002 | 05:17 PM
KingDsi's Avatar
You cut at the bolt holes
Old Dec 27, 2002 | 06:39 PM
Rain_man's Avatar
New User
Default Re: Expansion slots. Turbo guys.. Take a peek... (KingDsi)
Out of curiosity, do cast mainfolds like the inline pro need to have slots cut as well?
Old Dec 27, 2002 | 09:10 PM
The Mole's Avatar
Default Re: Expansion slots. Turbo guys.. Take a peek... (DarksideDC4)
i was wondering the same thing...?
chris
Old Dec 27, 2002 | 09:22 PM
ffgeon's Avatar
See red lines
ok DIY you see where you have the middle red line? it is right in the middle of the bolt hole. cut all three right down the center! i am surprised a maxrev manifold was not cut. and the reason that the fullrace one is not cut is because it went to vegas not finnised. that was acctually the only thing that wasnt done to it, but i assure you it did get cut before shipping to a customer!
Old Dec 27, 2002 | 09:28 PM
Arturbo's Avatar
Better than steak
25 Year Member
No, because its a cast stainless steel.
art
Old Dec 27, 2002 | 10:06 PM
HXMan's Avatar
Default Re: Expansion slots. Turbo guys.. Take a peek... (ffgeon)
[Modified by DIY_Racing, 4:15 PM 12/26/2002] ok DIY you see where you have the middle red line? it is right in the middle of the bolt hole. cut all three right down the center! i am surprised a maxrev manifold was not cut. and the reason that the fullrace one is not cut is because it went to vegas not finnised. that was acctually the only thing that wasnt done to it, but i assure you it did get cut before shipping to a customer!
Should it be cut completly thru in all 3 positions?
Old Dec 27, 2002 | 10:21 PM
ffgeon's Avatar
Default Re: Expansion slots. Turbo guys.. Take a peek... (HXMan)
yes, cut em all the way through. you want to do this for 1. to relieve stress created during welding and 2. to allow the manifold to "breathe". that is expand and contract at its own will. if the flange is not cut, the chance of a weld breaking goes up drastically. do yourself a favor and cut the flange
Old Dec 28, 2002 | 01:33 AM
Charles B.'s Avatar
what is the difference b/w cutting down the middle like on the max-rev as opposed to cutting at every single hole like the full-race?
Old Dec 28, 2002 | 01:42 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Expansion slots. Turbo guys.. Take a peek... (SuperDuperEG)
You should do both, and full race does do this. But the pic I have was one that had not yet been finished like ffgeon stated. They did infact finish the expansion slots on the manifold I have pics of.
art
