obd jdm dohc vtec ecu running a sohc vtec crx?
Old Dec 25, 2002 | 09:07 PM
foesicks's Avatar
Default obd jdm dohc vtec ecu running a sohc vtec crx?
Is their any way you can use a jdm dohc vtec ecu to run a d16z6? Could you just wire it up with the oil pressure and vtec so that the ecu controlls x over. Dont know what you would do about not being able to hook up a knock sensor if it matters.
Old Dec 25, 2002 | 09:11 PM
Ef Whore's Avatar
Default Re: obd jdm dohc vtec ecu running a sohc vtec crx? (Foesicks)
it has been done, expect to run rich and be breathing gas fumes.
Old Dec 25, 2002 | 09:39 PM
big pete's Avatar
Default Re: obd jdm dohc vtec ecu running a sohc vtec crx? (Ef *****)
why dont you run the si ecu and get a vtec controller or just sell the pr3 and get a p28
Old Dec 26, 2002 | 09:00 AM
foesicks's Avatar
Default Re: obd jdm dohc vtec ecu running a sohc vtec crx? (big pete)
Thats why I have right now is the si with an msd switch, I dont wanna convert to odb1 unless I can find someone that is willing to help me out with it, but I dont feel like paying anyone to do it. Im sure it can be that hard I know a few people that have maid their own harness but Im not t sure if their still around. I,m gonna go check it out anyhow, it would be much better 1 then 0 because of hondata and boost.
mario_a_05
Dec 8, 2009 12:48 AM
todubbled1
22
Mar 7, 2009 07:12 AM
DA91TEGGY
21
Apr 14, 2005 07:03 PM
4gvtec
10
Feb 28, 2002 06:01 PM
