I was pondering this...help me out please
I figured if i did a minime i would do a full obd 2 conversion. I've got the y8 ecu and for the in-dash and engine harness i say that'd be about 250 and a head for about 200 and i could use my existing dizzy and fuel injectors and stuff. So totaling something around 500-600 dollars and get about 130 hp with something close to 11:1 cr. Or i could take my non vtec sohc and put in some high comp pistons (11:1) and for about 450-500 dollars i could have about 130 hp (i figure this because i set up a ratio between my current c/r and hp and new c/r to figure out new hp). So why would i want to do a vtec head swap if i can in theory pull the same numbers with less work? Am i missing something?
is that 92 octane material? Now that im almost set up on not going vtec Im thinking about stage four crane cam with a low spooling turbo
yeah i figured i'd just do it for some low end power too, we'll have to see how that works out with 11:1 cr if i decided to do it. thanks for the info
that is like the same setup im gonna build, what all are you doing to the motor, bearings etc...... are you getting oversized pistons and are you upgrading your valve train?????
You cannot use your current distributor, you will need an OBDI or OBD2 distributor.
you will also need 92+ civic injectors since the OBD2 ECU won't work with the ones you have. You will also ned to find two 4 wire O2 sensors and wire them to the ECU. OBD2 needs both O2 sensors, one before the cat and another one after the cat. 4 wire O2 sensors are expensive. Plus you will need a harness from a OBD2 car to get all the plugs you will need to rewire the extra stuff.
Nothing impossible to solve, but worth considering.
yeah i've decided to go for high comp pistons and stage 4 crane cam. I really hope to turn my wagon into an all out race car. I figure by the time the whole obd2 conversion is done and the head is on there i ccould have one mean setup sans vtec. bah, vtec is ricer speed
rule of OBD's
u can go foward on OBD electronics... u can go back
u cant also jump 2 generations of OBD without being a royal bitch!!
i agree with everything spaceball said...
u seen the car harness on a OBDII car?? i had a 00 EX for any part i needed when i first started swaping....
on our cars... right at the ecu the harness splits into the dash, and engine compartment... and after engien it returns to the inside tru the drivers side..
on OBDII (00 EX for this example) the harness goes directyl from ecu to engine compartment, then to the inside tru the driver side.. u will need to rewire ur whole car... wich its A LOT OF WORK, and waste of money when u got better chances and options....
i dont really see the advantage of doing it as long as you have it tuned with the ecu your runningi would stick non obd run a non obd teg ecu
rule of OBD's
AwwsChwA
14
Nov 21, 2011 09:33 PM
helpmeplease
Feb 25, 2011 08:56 PM
