Advice on Turbo Manifold
Old Dec 25, 2002 | 07:12 PM
Adriano's Avatar
Default Advice on Turbo Manifold
What do you guys think about this manifold design. I saw it on ebay. It's looks simple and i could make it myself (i cut the pipes and flange and my friend will weld it for me). Is the design good or a waste of time? Thanks
Old Dec 25, 2002 | 07:19 PM
RenoRacing's Avatar
Default Re: Advice on Turbo Manifold (brryder)
this style is cheap, easy, and fairly effective, unless you're going full race, then it'll do!!!
Old Dec 25, 2002 | 07:23 PM
tony1's Avatar
Default Re: Advice on Turbo Manifold (HavokRacing)
The flow on that manifold is not going to be good, at all!! Cylinders 2 & 3 fire directly into a wall. Most log type manifolds like this locate the turbo flange directly onto the log. This one runs another pipe to the turbo. I wouldn't put it on my car....
Old Dec 25, 2002 | 07:33 PM
Full-Race Javier's Avatar
if ur already cutting the pipes, then buy more material and make a tubular one. it will take more time and $, but its worth it. why not do it right the first time?
Old Dec 25, 2002 | 07:52 PM
tony1's Avatar
Default Re: Advice on Turbo Manifold (Blake)
So you are basiclly saying you would never put ANY log style manifold on any of your cars?
Did I say that? I said I would never put THAT manifold on my car. That is a much worse design than your typical log manifold.
Old Dec 25, 2002 | 08:54 PM
TurboITR's Avatar
on a log manifold, #2 and #3 will always shoot staight into a wall
this is not true at all - i have seen quite a few log mani's that dont fire into the walls...
not a very good design...
Old Dec 25, 2002 | 09:14 PM
johnisenglish's Avatar
Default Re: Advice on Turbo Manifold (TurboITR)
Definetly. Look at a Revhard, Max-Rev, Drag, etc. They are all designed with maintaing good flow in mind, so their runner merge gracefully with the Turbo, rather then having to make a full 90 degree turn into a seperate pipe on this manifold. If I were you, I'd look in to making a manifold similar to those used by Jon at thedropshop
Old Dec 25, 2002 | 09:34 PM
WA  DA  TA's Avatar
Default Re: Advice on Turbo Manifold (johnisenglish)
I would love to see the flow bench #s of this manifold... wait, actually i would not
Old Dec 25, 2002 | 09:38 PM
Evil EG's Avatar
Default Re: Advice on Turbo Manifold (gsx4R1)
What do you guys think about these....
the guy says there tig welded....
I just dont like that ugly wastegate tube how it turns like that...
[Modified by BVM, 12:42 AM 12/26/2002]
Old Dec 25, 2002 | 09:56 PM
dmotoguy's Avatar
Default Re: Advice on Turbo Manifold (BVM)
its a lot better than the first one posted..
Old Dec 25, 2002 | 10:07 PM
The Mole's Avatar
Default Re: Advice on Turbo Manifold (dmotoguy)
ditto
chris
LeandroR
Apr 4, 2013 01:13 PM
ef9hatch
Jun 1, 2006 06:44 PM
CBURKE
May 12, 2006 06:41 AM
lkailburn
Welding / Fabrication
Jul 31, 2005 11:57 AM
TeamDOHCside
Jul 2, 2003 11:19 AM
