What other bolt on parts can i get?
Old Dec 25, 2002 | 02:06 PM
BseriesHatch's Avatar
Default What other bolt on parts can i get?
I have a ZC motor with a header, intake, 2 1/4 inch exhaust, test pipe(where the cat is suppose to be), fuel pressure regulator, and a PG7 ecu. I want to know what other bolt on parts are worth buying. I heard pulleys are pretty good. I also heard that cam gears really don't do that much. I'm trying to save money by doing all the bolt ons i can do before internals and the bottle. Anything else good?
Old Dec 25, 2002 | 02:15 PM
spettinger's Avatar
Default Re: What other bolt on parts can i get? (Novtech)
you pretty much have all the bolt on's. i would suggest making a box to protect the intake filter from heatsoak if you use a short ram, as well as heatwrapping the intake piping.
other than that, new fuel filter, plugs, wires, O2 sensor, maintenance.
i would not use aftermarket pulleys unless the bottom end is balanced. even then, i still don't like them. buy a lighter flywheel.
Old Dec 25, 2002 | 02:25 PM
Louie B.'s Avatar
depends on what you consider "bolt on",
Cams are a good idea, I'm not sure what's out there for the ZC though. And cam gears do make a difference if you know how to tune them right. Intake manifold from a D16Y8, larger throtle body, good clutch, lightened flywheel. Also, what transmission are you using? good transmission gearing make a big difference.
Most importantly Tuning, Tuning, Tuning!! Just slapping parts on and going won't give you near as much power as properly tuning the entire system.
as far as pulleys go, accesory pulleys like AEM sells are ok, but think twice before changing the crank pulley. read this post for more info:
https://honda-tech.com/zerothread?id=368411
Old Dec 25, 2002 | 02:36 PM
Default Re: What other bolt on parts can i get? (thumpu77)
I'm running the Si tranny. They say it has the quickest acceleration.
Old Dec 25, 2002 | 02:47 PM
Louie B.'s Avatar
Old Dec 25, 2002 | 06:09 PM
I Gotta Question's Avatar
I think otherwise. I raced a stock si rex and we were close. Like a car length close. So why do you suppose that happened?
Old Dec 25, 2002 | 10:56 PM
Louie B.'s Avatar
Default Re: What other bolt on parts can i get? (89_CRX_HF)
was it 1/4 mile from a dead stop? did he pull ahead at first but you caught back up in the end?
could've been that your extra power made up for your higher gearing, or maybee that guy didn't know how to drive as well as you. Also, the Si is heavier than the HF
[Modified by thumpu77, 11:57 PM 12/25/2002]
Old Dec 26, 2002 | 10:48 AM
SteveeeO's Avatar
novtech - what kinda times are u running with those mods?
Old Dec 26, 2002 | 11:06 AM
ExospeedAMcrx's Avatar
Default Re: What other bolt on parts can i get? (SteveeeO)
we have cams available for the ZC dohc. we dont advertise them becuase we dont have cores available if you are willign to send yours to get done, let me know.
Wil
Old Dec 27, 2002 | 09:32 AM
The_PissingDog_Crx's Avatar
Default Re: What other bolt on parts can i get? (exospeedAMcrx)
Get a Short Throw Shifter.
88aeFC3S
Mar 10, 2010 12:07 PM
NEO_FOLLOWER2
Honda Civic (2001 - 2005)
Dec 2, 2008 08:39 AM
JCCOOL43
Feb 12, 2004 11:56 PM
-Whitey-
Oct 25, 2002 11:07 AM
CRrex
26
May 16, 2002 12:56 AM
