D16A6 Cam Update
Old Dec 25, 2002 | 01:51 PM
slowman's Avatar
I took way too long
Default D16A6 Cam Update
Here's where i will call it a day. I need the cam seal that goes by the cam gear which i will pick up tomorrow and get this job done. I cant wait!!!!
Rocker arm assembly
Stock cam is outta there!
Well until tomorrow.....
Old Dec 25, 2002 | 02:23 PM
sporkcrx's Avatar
Default Re: D16A6 Cam Update (B16_madman)
what kinda cam? post the results.
Old Dec 25, 2002 | 04:27 PM
EG8R's Avatar
Default Re: D16A6 Cam Update (sporkcrx)
Holy crap that's dirty!!! Someone missed an oil change or 2.... Yikes....
Old Dec 25, 2002 | 04:37 PM
slowman's Avatar
I took way too long
Default Re: D16A6 Cam Update (mr. skelly)
heheh yeah, it was from the previous owner, ive changed it 2 time since ive had it from july 1. when i p and p it, i will give it an acid bath. and it's a Crane Stage 2 D16A6 cam.
Old Dec 25, 2002 | 05:15 PM
PaImportTuner's Avatar
Default Re: D16A6 Cam Update (slowmanEF)
your really brave for 15.. i'm 19 and i dont like the feeling of my hands touching the internals of my car.. cause it seems everything i touch BREAKS!!
How hard is it to do?? just want to know how hard it is to remove all the stuff and install springs/adjust the valves.??
I want to get an Exospeed StreetA6 or SR909A6 cam.. just dont know which one to get.
Old Dec 25, 2002 | 05:20 PM
slowman's Avatar
I took way too long
Default Re: D16A6 Cam Update (PaImportTuner)
Well it really quite simple acutually. Remove the valve cover and then there are about 14 bolts that you loosen and the entire rocker arm assembly comes off exposing the cam then you just take the cam out. that's where im currently at. just need to get a cam seal to let the project progress. im going to get one tomorrow so it will be done. then you just slide the new cam in and adjust everything and bam. exospeed cam is a regrind and this cam is a fresh one that is made.
Old Dec 25, 2002 | 05:54 PM
zcivicz's Avatar
guess i shouldn't swap in an A6 cam for my mpfi DX motor, huh?
how much was the stage 2 crane cam??
Old Dec 25, 2002 | 07:00 PM
slowman's Avatar
I took way too long
Default Re: D16A6 Cam Update (zcivicz)
$317.99
I hope it's worth it.
Old Dec 25, 2002 | 08:13 PM
slowman's Avatar
I took way too long
When i get this in here, how much fuel will it be craving? i have an OEM honda regulator i bumped up 5 psi...is that good? +/-?
Old Dec 25, 2002 | 10:10 PM
Broken Gearbox's Avatar
Damn it looks dirty in there!!!
Post more pictures when you drop the new cam in there
Also how many miles are on the A6??
Old Dec 25, 2002 | 10:14 PM
slowman's Avatar
I took way too long
Default Re: D16A6 Cam Update (CRXSiBeater)
Imust be a old timer at 23..haha...that thing should make for some mean top end..ya get any help from ur old man or friends????Prop for being young and workin on it urself....I remember being 16 workin under a pit...what kind of header is that???looks nice..also Crane Cams are dope..they make some kick *** cams for doemestics and im glad they make em for our cars now...Im going with the stage 1 crane unless Skunk 2 makes a Sohc cam or i get a b16a swap..then its screw sohc...and use it as a paper weight
No, i think i'm a youngtimer. hehe. its an eBay header, i had to stoop low on my performance parts since i have no job. but went all out on the cam. yeah, i will get some help from my old man when i have to readjust the valve lash. stay D series man!!
EG8R's Avatar
I've had my car since Oct 17 or so. Changed it that night. And it will now get changed on the first Wednesday of every month....
Old Dec 25, 2002 | 10:15 PM
slowman's Avatar
I took way too long
Default Re: D16A6 Cam Update (dEF juNKie)
allrite i will. and it just turned 137K. and i will also have video/audio up tomorrow if all goes well. i will keep everyone posted.
Old Dec 26, 2002 | 02:24 AM
ah my car has 135k on it.
I was wondering are you using your old(137k) valve springs and stuff? So basically your just replacing cam, cam seals & [b]readjusting[b] your valves?
i mean do you need to replace the retainers and springs that bad or what??
Old Dec 26, 2002 | 06:30 AM
vacrx73's Avatar
I have the stage one cam in my CRX, Crane recommended replacing the valve springs with new stock ones so I did. Where did you get your Crane from cause I got mine for 260 bucks.
Old Dec 26, 2002 | 07:11 AM
altoid's Avatar
Default Re: D16A6 Cam Update (emsp)
where did you get your crane cam? Im looking into the stage 4, they got it for about 440$ shipped
Old Dec 26, 2002 | 08:16 AM
ExospeedAMcrx's Avatar
I'll guarantee you that our SR909 cam will make more power than the Crane stage 1. I have tried a crower and when the Crane first came out and couldnt compare to our cams. just look at the numbers. this is with our head package and with bolt ons.
HEAD package/upgraded valvetrain with the SR909 cam. dynos at 138 to the wheels, stock block. thats over 40hp gain to the wheels on a basic build up. corrected HP gain to the flywheel should be around 155 or so. at 155hp from 109 stock... I believe thats impressive.
Wil
Old Dec 26, 2002 | 08:36 AM
Default Re: D16A6 Cam Update (exospeedAMcrx)
whats the pros and cons on your cams if any? crane new VS exospeed regrinds...
what the difference between the 2.. what kind of waranty? what about quality? do you use our core or one you already have.
Old Dec 26, 2002 | 09:18 AM
if i were in your shoes, it would be a matter of preference. if new cores like the Crane are really important to you, then I'd go with those. but if you dont mind a regrind, then i woudl suggest ours.
as far as quality, my own personal SR909 cam went through 100k+ miles, daily driven and raced also every weekend. still performed like it did from the beginning. we use our core or yours, whatever you prefer.
Old Dec 26, 2002 | 09:22 AM
joshwhe's Avatar
ill be ordering a new cam soon, a regrind is fine, i have a a6 head, i would like a "big" cam so i was wondering what sizes you have to offer and do you offer valve springs?
Old Dec 26, 2002 | 09:52 AM
Default Re: D16A6 Cam Update (joshwhe)
we actually have 3 cams available for the D16a6. we recoommend the SR909 which is the most street/track friendly cam we have. you can street our 'Race' cam but that is going to the extreme and most dont want a very lopy idle.
If you are interested in even a wilder cam than our 'race' cam, let me know. we have another one higher than that but seriously only for dedicated track only racers. call us up at 818-355-6156
and if you are even way more hardcore and want to go full full race.. we are developing a new cam from a new billet core which should be available later this year. most likely going to be for alcohol injected applications.
Old Dec 26, 2002 | 10:00 AM
slowman's Avatar
I took way too long
I got mine at jegs. and i will be replacing the cam seal which is why progress has been stopped until i get one.
Old Dec 26, 2002 | 12:08 PM
joshwhe's Avatar
I want a lopey idle.. the race cam sounds good, what about the valve springs. which do you suggest.
Old Dec 26, 2002 | 12:40 PM
Which Cam would be good to use if you wanted to run some N20??
Old Dec 26, 2002 | 02:33 PM
my_slow_civic's Avatar
I want a lopey idle
If that's all you want, there are other ways of getting it.
Good luck on that cam, make sure you use your torque wrench too.
