Cusco Zero 1 coilovers?
wait for the jdm peeps to come back from the holidays...
you'll get an answer then...
why not step up to the Zero 2 for higher spring rates?
well cuz I already purchased the Zero 1's and I got it for a good price. The Zero 2's were kinda outta my range
I'm not like a hardcore road racer so I didn't need something with that much adjustability in dampening
then what fault do you find with the 9/5k spring rates...seems like they will suit your needs just fine
You can replace those springs with Eibach ERS springs. They come in various dimensions. I'm guessing the I.D. of your Cusco Springs are 60mm. If so, there are tons of ERS springs available with varying spring rates.
If your question is whether or not the damper will handle stiffer springs, then I can't help you on that one.
