What fan to use with fluidyne?
Old Dec 25, 2002 | 02:08 AM
R-1303's Avatar
Default What fan to use with fluidyne?
Getting an 38mm fluidyne and was wondering which fans to use, spal, permacool, etc..and which size?? this will go on a 2000 ITR turbo, I plan to keep a/c and maximize the space between the manifold and fan.
sorry, new to this fan thing....thanks.
Old Dec 25, 2002 | 12:16 PM
R-1303's Avatar
Default Re: What fan to use with fluidyne? (R-1303)
somebody has to be running a fluidyne with a snail!! come now!
Old Dec 25, 2002 | 12:21 PM
Etylorcen's Avatar
Try searching. Anyhow, buy some push style fans and put the fans on the otherside it'll make your life easier.
Old Dec 26, 2002 | 02:14 AM
R-1303's Avatar
Default Re: What fan to use with fluidyne? (Etylorcen)
i thought about putting push fans on the out side but people are telling me that the radiator won't get sufficient cooling.
Old Jan 19, 2003 | 01:35 PM
954DR's Avatar
New User
You're correct the a/c compressor side will not get enough cooling IMO w/ a pusher type fan.
I would recommend going with a puller on the a/c side. Spal makes good fans. Try this link http://www.jaycorptech.com/shop/shop...Cooling+Fansns
[Modified by 954DR, 10:55 PM 1/19/2003]
Old Jan 19, 2003 | 01:47 PM
RyanAutry's Avatar
Default Re: What fan to use with fluidyne? (954DR)
My friend uses a FAL fan.
Old Jan 19, 2003 | 02:35 PM
echo999's Avatar
New User
I run the fluidyne with turbo (keeping A/C)
There is about 2.5" clearance between the compressor and the radiator...
FAL will not fit (not even the slimline).. I ended up buying a SPAL 7" fan
(2.05") and mounted it as far to the drivers side as I could.. I have about a
.75" clearance from the compressor in this configuration...
NOTE that since I run open wastegate, the exhaust started melting the fan (it's plastic), so I put a layer of aluminum tape all over the exposed surfaces.. This
seems to have stopped the melting.
[Modified by echo999, 11:36 PM 1/19/2003]
K2420
Sep 8, 2017 02:27 PM
KevinEF7
Dec 7, 2012 12:17 PM
GRANT!
Oct 27, 2009 03:37 PM
kyle h.
Welding / Fabrication
Jun 22, 2005 07:18 PM
Rah Rah
Aug 4, 2003 09:00 PM
