How can you tell a 97 ITR Cluster vs. a 98+ JDM Cluster?
Old Dec 25, 2002 | 12:35 AM
skafia's Avatar
25 Year Member
Default How can you tell a 97 ITR Cluster vs. a 98+ JDM Cluster?
I thought it was the SRS icon, but I've seen 97's with SRS's also... how can you definitely tell?
EDIT: Okay, from what I understand, I created this picture:
Seems according right? BUT what cluster do you get if a 98SpecITR does not have ABS?
[Modified by skafia, 12:55 PM 12/25/2002]
Old Dec 25, 2002 | 07:13 AM
rated_r's Avatar
Default Re: How can you tell a 97 ITR Cluster vs. a 98+ JDM Cluster? (skafia)
jdm cluster, speedo only goes up to 180kph
Old Dec 25, 2002 | 07:48 AM
ckkl's Avatar
Default Re: How can you tell a 97 ITR Cluster vs. a 98+ JDM Cluster? (rated_r)
Dude, I'm pretty sure he wants to know the visual difference between the ITR clusters of the 96Spec JDM ITR and the 98Spec JDM ITR one...
I'd also like to know...
Old Dec 25, 2002 | 08:56 AM
Rob :190:'s Avatar
Default Re: How can you tell a 97 ITR Cluster vs. a 98+ JDM Cluster? (ckkl)
silly australian. carefully re-read the post
[Modified by Rob :190:, 12:57 PM 12/25/2002]
Old Dec 25, 2002 | 09:13 AM
D's Avatar
D
USDM clusters after 98 have the security key icon.
Old Dec 25, 2002 | 10:55 AM
skafia's Avatar
25 Year Member
Default Re: How can you tell a 97 ITR Cluster vs. a 98+ JDM Cluster? (D)
The first cluster has the SRS icon, which appears to be a 98Spec cluster, and the second cluster doesn't, so it's a 96Spec, BUT the auction for the first one on ebay says its for a 94-97 (http://cgi.ebay.com/ebaymotors/ws/eB...tem=1875262341), so that confused me!
Old Dec 25, 2002 | 12:11 PM
Downey's Avatar
how much are these worth?
Old Dec 25, 2002 | 12:13 PM
Unlimited's Avatar
New User
i thought there are some 98SpecITR's without SRS
Old Dec 25, 2002 | 12:45 PM
Saga's Avatar
Default Re: How can you tell a 97 ITR Cluster vs. a 98+ JDM Cluster? (Unlimited)
exactly. The best way to tell is to look at the circuit board.
Old Dec 25, 2002 | 12:51 PM
skafia's Avatar
25 Year Member
Default Re: How can you tell a 97 ITR Cluster vs. a 98+ JDM Cluster? (Saga)
I found it... 98+ Integras have the icons switched around from pre 98's. Just look at the door ICON, 98+ Clusters it at the top. Pre 98's have it to the right.
Pre 98's have the ABS icon at the bottom as opposed to the ABS icon at the top for the 98+ (my old GSR had the ABS icon on the bottom)...
Its hard to see the circuit board on ebay, etc, but what do you look for if you can see the board?
Old Dec 25, 2002 | 08:10 PM
ckkl's Avatar
Default Re: How can you tell a 97 ITR Cluster vs. a 98+ JDM Cluster? (Rob :190:)
Ok... I see two pics, comparing 96Spec and 98Spec JDM ITR clusters... some have SRS some don't... am I missing something? (Now that the original question has already been answered)
btw I'm not Aussie but I'm in Australia subtle difference...
Old Dec 25, 2002 | 09:04 PM
Q-OnE's Avatar
good pics
Old Dec 25, 2002 | 11:37 PM
Dirt's Avatar
Old Dec 26, 2002 | 12:37 AM
skafia's Avatar
25 Year Member
Default Re: How can you tell a 97 ITR Cluster vs. a 98+ JDM Cluster? (BrewCityR)
Dumbass.
Old Dec 26, 2002 | 09:18 AM
SMZ GSR's Avatar
Then i don't understand mine.
mine has Maint Req., "BRAKE" instead of (!), ABS, SRS, seatbelt by gas light, little key icon, and even cruise control.
here's a pic
Old Dec 26, 2002 | 09:50 AM
Dirt's Avatar
LOL! It's a joke, boy. Take one once in a while.
Old Dec 26, 2002 | 10:31 AM
skafia's Avatar
25 Year Member
Default Re: How can you tell a 97 ITR Cluster vs. a 98+ JDM Cluster? (SMZ812)
here's a pic
LOL... talk about customizing your gauge cluster....
Old Dec 26, 2002 | 10:32 AM
Chris N's Avatar
LOL!!
Old Dec 26, 2002 | 11:12 AM
SMZ GSR's Avatar
why is it custom? i mean i know some of those icons shouldn't be there, so what gives. Not that i'm complaining though, cuz hell, i got it with 16k KM on it for only $175 shipped.
Old Dec 26, 2002 | 11:33 AM
B2FiNiTY's Avatar
It looks like a USDM cluster with swapped JDM gauges.
Old Dec 26, 2002 | 01:41 PM
SMZ GSR's Avatar
Default Re: How can you tell a 97 ITR Cluster vs. a 98+ JDM Cluster? (B2FiNiTY)
hmm maybe, but wouldn't the number then be off? (not sure just guessing)
Old Dec 26, 2002 | 04:21 PM
B2FiNiTY's Avatar
What do you mean the numbers? Is it on your car? I'll have a look at it when I meet up with you.
Old Dec 26, 2002 | 05:28 PM
SMZ GSR's Avatar
ok, yea sorry about unclarity. i meant the speedometer, like wouldn't it be off if just the gauges were switched. i'm don't know crap about clusters so i tend to ask dumb questions
Old Dec 26, 2002 | 06:10 PM
Project SSAP1's Avatar
u r correct sir.. i just got my 94-97 itr cluster..take a peak
[Modified by Hybrid Accord, 10:14 PM 12/26/2002]
Old Dec 26, 2002 | 08:32 PM
b18bvtec4drteg's Avatar
Default Re: How can you tell a 97 ITR Cluster vs. a 98+ JDM Cluster? (Hybrid Accord)
This is a real 94-95 ITR cluster
How do I know? I made it! Look it has Cruise Control too!
