polished my maxrev manifold+painted piping=*bling bling* pic intensive!
Old Dec 24, 2002 | 10:12 PM
lilxvtecxpwr's Avatar
Default polished my maxrev manifold+painted piping=*bling bling* pic intensive!
sup guys. im piecing together a turbo kit. i polished my maxrev manifold and my fingers are still cramped from 2 days ago. anyway, here are some pics...(it looks shitty in some pics because i washed it with a damp cloth and it left streaks that i didnt see until the pics came out :hammer :
[Modified by lilxvtecxpwr, 1:14 AM 12/25/2002]
[Modified by lilxvtecxpwr, 1:17 AM 12/25/2002]
Old Dec 24, 2002 | 10:15 PM
Default Re: polished my maxrev manifold+painted piping=*bling bling* pic intensive! (lilxvtecxpwr)
also, i bought some piping off h-t for really really cheap and the paint was chipping and some of the piping had small rust spots in it.
it looked like this before:
then i sprayed some aircraft remover on it and it looked like this:
then i sprayed it with some aluminum colored spraypaint and clearcoat for the shine:
which do u like best? i like the aluminum look :
Old Dec 24, 2002 | 10:18 PM
CzanSOHC's Avatar
you use high temp paint?
[Modified by CzanSOHC, 11:19 PM 12/24/2002]
Old Dec 24, 2002 | 10:26 PM
dmotoguy's Avatar
Default Re: polished my maxrev manifold+painted piping=*bling bling* pic intensive! (CzanSOHC)
looks really good!
Old Dec 24, 2002 | 10:51 PM
skrewdlude's Avatar
Hey,
What did you do to polish the manifold?
Thanks,
Josh
Old Dec 24, 2002 | 11:05 PM
shortyz's Avatar
Default Re: polished my maxrev manifold+painted piping=*bling bling* pic intensive! (skrewdlude)
just keep going up in grits to like 800 or 1000 and use a spiral sewn buffing wheel with some black emery wax on it. (use angle grinder)
Old Dec 24, 2002 | 11:08 PM
this is what i did to polish my manifold:
1. get coarse, fine, very fine, and extra extra fine sand paper (100, 220, 800, 1500, etc.) or any combination really. just whatever that will end up very very smooth.
2. start sanding with the very coarse sandpaper. then work your way up to the very fine grit. keep sanding the **** out of it until it is very smooth. when you get to like 1500 grit sandpaper, use waterproof sandpaper and sand with water. it helps alot.
3. get some mother's metal polish and apply some on it. then bust out the dremel tool w/ the round felt buffer/polisher. use the buffer and polisher and buff off the polish. the manifold should be pretty damn shiny after that.
4. repeat if neccessary.
Old Dec 24, 2002 | 11:11 PM
FredoSP's Avatar
Old Dec 25, 2002 | 12:07 AM
shortyz's Avatar
Default Re: polished my maxrev manifold+painted piping=*bling bling* pic intensive! (FredoSP)
littevtec. heres a tip for next time. use a spiral sewn buffing wheel after even like 600 grit. u save yourself all that time and its fast.
cheers and merry xmas man!
Old Dec 25, 2002 | 12:24 AM
B18EG6's Avatar
Default Re: polished my maxrev manifold+painted piping=*bling bling* pic intensive! (shortyz)
What is this spiral sewn buffing wheel? Is it in my handy dandy dremel polishing kit?
is this it?
This is right after 400 grit sandpaper...should it be more than this, at this stage???
Old Dec 25, 2002 | 12:28 AM
Default Re: polished my maxrev manifold+painted piping=*bling bling* pic intensive! (B18EG6)
i also used those little gray round things on the top right corner in your picture of the polishing kit. i dont know what its called but it worked good
[Modified by lilxvtecxpwr, 3:29 AM 12/25/2002]
Old Dec 25, 2002 | 12:31 AM
B18EG6's Avatar
at what stage did you use them?
[Modified by B18EG6, 4:31 AM 12/25/2002]
Old Dec 25, 2002 | 01:28 AM
Pat's Avatar
Pat
what's the hole by the turbine flange for?
Old Dec 25, 2002 | 02:08 AM
Default Re: polished my maxrev manifold+painted piping=*bling bling* pic intensive! (Pat)
if you are talking about the hole by the wastegate flange on the 3rd runner, thats the hole tapped for EGT gauge.
Old Dec 25, 2002 | 07:02 AM
B18EG6's Avatar
Ahhhh i see it. Looks kinda like a shadow? I dont know
Old Dec 25, 2002 | 11:06 AM
shortyz's Avatar
thats a spiral sewn wheel. u get a 4" and put it on your angle grinder.
they last a long time and work great.
Old Dec 25, 2002 | 11:42 AM
B18EG6's Avatar
ohhhh ok, i got it
Old Dec 25, 2002 | 12:42 PM
wickedxboi's Avatar
wow! that good badass
Old Dec 25, 2002 | 02:24 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: polished my maxrev manifold+painted piping=*bling bling* pic intensive! (wickedxboi)
you should look into using CAST paint. its a high temp paint with metal in it. it resists oil and gas also.its like a nice gunmetal color!! you can get it at almost any autoparts store.
Old Dec 25, 2002 | 02:47 PM
JV's Avatar
JV
Who?
Default Re: polished my maxrev manifold+painted piping=*bling bling* pic intensive! (MotorMatrix.com)
Looks nice. How long did it take...?
Old Dec 25, 2002 | 03:47 PM
Pat's Avatar
Pat
actually, I was wondering about the hole on the bottom, or is that even a hole?
Old Dec 25, 2002 | 04:18 PM
mskibbz-T's Avatar
[QUOTE]
My MaxRev B series manifold has a slit between each cylinder's flange... Does anyone know why the slits are on my manifold? I'm guessing it would make it more resistant to cracking by allowing a little movement... but I am no engineer
Old Dec 25, 2002 | 04:32 PM
Default Re: polished my maxrev manifold+painted piping=*bling bling* pic intensive! (mskibbz)
yea, i've seen some maxrev manifolds that have the slits on the head flange. my doesnt....i dunno...but those slits do make it more crack resistant
also, ive seen alot of maxrev manifolds that dont have studs on the wastegate flange, and i've also seen alot with (like mine)
Pat: i see what you are talking about, the little black dot on the bottom right. its not a hole, it just looks like a hole because of the lighting. if u look at the pic with the manifold ontop of the dremel tool box, you'll see that there isnt a hole. thanks for the replies.
Old Dec 25, 2002 | 04:51 PM
chris@cfranklins's Avatar
to the guy with the motor mount if you polish the thing right it will look like chrome when you are done
Old Dec 25, 2002 | 07:37 PM
Full-Race Javier's Avatar
Default Re: polished my maxrev manifold+painted piping=*bling bling* pic intensive! (gsrcrx)
the expansion slot are there to help prevent cracking and relieve stress,some didnt want the slots when they first came out. also, there were studs on the wg flanges on a bunch of manis when they first came out. i believe they all come tapped now.
[Modified by javierb14, 8:38 PM 12/25/2002]
