Stock springs question.
Old Dec 24, 2002 | 08:41 PM
SkylineGTR's Avatar
Default Stock springs question.
I'm going stock on my 90 CRX Si and i forgot which stock springs go in the front. One type is skinnier than the other and is less space between each coil and the other type is more fatter in circumfrence and their is more space between the coils. By looking at the Chilton, my guess is that the skinnier one with less space between each coil is the front. Am i correct or not. Someone help, thanks.
Old Dec 24, 2002 | 10:22 PM
EG8R's Avatar
Default Re: Stock springs question. (SkylineGTR)
I believe the skinny ones are the fronts....
Old Dec 24, 2002 | 11:06 PM
SkylineGTR's Avatar
Default Re: Stock springs question. (CRXSiBeater)
OK, two guys answered and i have two different answers. One said the fatter ones are the front and another saids the skinnier ones are the front, which is it?
Old Dec 25, 2002 | 05:52 AM
civicwagonman's Avatar
you want the fatter ones up front since its heavier there cause of the motor and trans.
Old Dec 25, 2002 | 11:36 AM
SkylineGTR's Avatar
Default Re: Stock springs question. (civicwagonman)
Well do you mean the fatter ones as in bigger diameter and a bit more distance between each coil? In reality, the one with less diameter and less distance between each coil is more stiffer and stronger. Do which is it guys, i don't want to put on the wrong springs and find out i have to change them again.
Old Dec 25, 2002 | 11:46 AM
REDBARON's Avatar
The ones with more space between each coil go in the front. These should also be stiffer and harder for you to push down on. The ones with less distance between each coil go in the rear, and will be easier go compress with your weight.
Peace.
Old Dec 25, 2002 | 05:55 PM
SkylineGTR's Avatar
Default Re: Stock springs question. (REDBARON)
Actually the skinnier springs with less space between each coil is harder to compress. The fatter springs with more space between each coil is easier to comopress. So which goes where guys, i'm still getting different answers. I know i can find out by asking a shop but they are all closed and i just want to do this while i have time during the holidays, thanks.
Old Dec 25, 2002 | 06:07 PM
zcivicz's Avatar
have you tried putting a spring on one of the struts to see which one is which ??
i am positive that the skinnier springs go to the front and the fatter ones go to the back.
Old Dec 25, 2002 | 06:38 PM
SkylineGTR's Avatar
Default Re: Stock springs question. (zcivicz)
Yes i did try and both fit. My first inital thought was that the fatter ones go in the front but the skinnier ones seem to fit better. Now i am just confused and i just want to make sure.
Old Dec 25, 2002 | 11:08 PM
Timmayeg's Avatar
New User
the ones with more space between each coil go in the rear, the ones with more coils and i belive are a bit heavier go in the front, the coils on the fronts are closer together
Old Dec 26, 2002 | 07:21 AM
keithv's Avatar
Default Re: Stock springs question. (91_ED6_Civic)
i am pretty sure one set is longer than the other. the longer ones go up front.
Old Dec 26, 2002 | 09:52 AM
REDBARON's Avatar
Default Re: Stock springs question. (breaka_1_9)
Ok, let me correct myself. I just took out my stock springs from my closet, and noticed what you're talking about.
The ones that have the coils farther apart from each other, and are skinnier in coil cicumference are the rears. They are also just a little bit shorter.
The fronts with have fatter coils, and also the coils are closer together, and will be a little taller.
Peace.
Old Dec 28, 2002 | 10:50 PM
SkylineGTR's Avatar
I just want to thank you guys for your input. I used them to decide which springs i would use and it worked.
stwokay
May 12, 2011 07:02 AM
AutoDB8
Suspension & Brakes
Apr 13, 2009 02:08 PM
B16CivicEX
Jun 30, 2006 07:37 PM
str8drift
Mar 29, 2006 04:26 PM
SkylineGTR
Dec 26, 2002 03:07 AM
