REMOVING heater blower?!?!?
Old Dec 24, 2002 | 07:45 PM
boostinb18's Avatar
Default REMOVING heater blower?!?!?
my heater blower is barely blowing out any air and is making hella noise... i want to pull it out to check it and see wtf is wrong with it....how hard is it to pull out the heater blower?? its right behind the glove box and i just havent tried to pull it out... has anyone done this??? how long did it take?? im pretty mechanically inclined.. ive done all work on my car and ****.. several swaps blah blah so i dont think it will be that difficult i just want to know about how long it took and was it a bitch??
thanks for the help!
boostin
Old Dec 24, 2002 | 08:05 PM
crexer's Avatar
Default Re: REMOVING heater blower?!?!? (boostinb18)
its really not that hard if you have taken out your dash before, that would take the longest time maybe an hour if you have taken it out and maybe longer if you havent because there are a lot of hidden bolts. the blower itself is easy to take out once the dash is gone. good luck
Old Dec 24, 2002 | 08:07 PM
boostinb18's Avatar
Default Re: REMOVING heater blower?!?!? (crexer)
do you have to pull out the dash?? and im not pulling the whole assembly behind the center consoel out just the heater blower behind the very right side of the glove box above the ecu... do i need to pull the dash to get this off???
thanks again!
Old Dec 24, 2002 | 10:23 PM
crexer's Avatar
allright i was wrong all you have to do is take off the glovebox and it should unbolt right off.
Old Dec 24, 2002 | 10:45 PM
LD_EGSICK's Avatar
yea its simple, there are i think 3 metal bracket that u have to remove first, the fan(motor) has 3 nuts that holds it in place, disconnect the wire harness first, the nut size should be a 10 mm.
Old Dec 25, 2002 | 01:17 PM
boostinb18's Avatar
Default Re: REMOVING heater blower?!?!? (mysiqu)
COOL!!!! im gonna try it today!! i hope something is just stuck in there and i dont have replace the whole unit..... thanks a lot for all your help guys!!!!
Old Dec 26, 2002 | 02:00 PM
SteveeeO's Avatar
i did mine and had to break off the black thing that surrounds the blower, other than that it's easy to put in
mine was all rusted away and the motor was grinding
GeorgeA
Feb 20, 2013 05:30 PM
hometheaterman
Sep 9, 2004 03:11 PM
lonefuzzy79
Oct 8, 2003 12:37 PM
Halive
11
Jul 6, 2002 10:49 PM
Coaster
Nov 30, 2001 11:53 PM
