my goal 300hp
well... i am very close to getting a civic and doing a b18b swap, hopefully within 1 months that will all be done, my goal is to have about 300 hp, what would be the cheapest way to get there, but do everything right. do i need to sleeve my block or just get pistons and rods, would you reccomend a turbo kit that would get me to my goal or should i piece one together myself, and in the end how much do you think im gonna spend on the motor, clutch, stronger axels?, lsd, ect..
i know there are lots of questions, but hopefully you guys can help me out on this
i was kinda thinking about that, but if i want to turn it into an all drag car later on in the future or just build it a lot more, i wouldnt want to be limited by the sohc, and i can get a b18b for about $700 from my friends junk yard... so its not gonna set me back too much for that
Smarter than you
revhard turbo kit, forged internals, block guard, hondata s200, profec b boost controller...boosting 12psi, 3" turbo back exhaust...
that sould get your real close
thats what i have except for the forged internals and block guard. motor is stock and almost at 300.
do you guys think this is a nice kit:
max-rev manifold
rev hard downpipe
tial 35mm wastegate
t3/t4 turbo
max-rev intercooler
hondata s200 w/boost
HKS ss bov
stainless oil lines
would have to get custom piping at muffler shop
$2849
from ks-motorsports.com
max-rev manifold
rev hard downpipe
tial 35mm wastegate
t3/t4 turbo
max-rev intercooler
HKS ss bov
stainless oil lines
$2849
With a stock junk yard LS motor and just under 12psi, i made 277whp and 241.5ft-lb tq. on 93 pump gas. The LS motor is definitely capable of 300whp around 15psi w/ the right turbo.
just make you own DP and for 300 hp u mean wheels or crank. im shooting for 250 wheel HP on a stock b16 block. with the right fuel manegment and tuning u could get 300. ive heard 12 psi on stock b series blocks is about as high as u want to go. but if u built up your block u could hit 300hp no problem.
i would probably push it as hard as possible with the stock block until i have the money to build it or something breaks, then build it
how hard would it be to tune the hondata, there isnt a hondata tuner within 500 miles of boise
[Modified by dmotoguy, 4:12 PM 12/25/2002]
Without forged internals at this level you're on borrowed time.
Build it right and it'll run 300 whp for a LONG time. No sleeve required.
Just keep close to stock sized pistons. (81mm- 81.5mm)
Jeffrey Atwood
[Modified by Jefnes, 8:02 PM 12/25/2002]
Tech edge wideband kit + Hondata
[Modified by CzanSOHC, 3:54 PM 12/25/2002]
how easy is it to screw up when doing your own tuning, i know what to do, but if i make too big of a correction or something could anything go wrong?
can you explain why i would need the wideband, well actually i guess thats self explanitory... if i had a wideband and the hondata, would i be able to just do runs up and down my road and tune it? or would i need a dyno?
take the car to a shop.
Have you ever driven a 300+ whp Honda? Yeah, you can tune the
part throttle and offbost/low boost on the street, the car will be too
damn fast to tune the topend on the street. Its possible, but difficult
with a 'partner'. Driver and 'tuner' in the car....
Jeffrey Atwood
Jeffrey Atwood
Jeffrey Atwood
Also when you tune a car it isn't done real time. You make a run, watch the datalogging, make changes, do and another run, repeat. You could totally tune your car on the street, but doing a dozen runs to redline is a bit much to ask of public streets.
A dyno/wideband is the prefered way, but a really good tuner could get your car really close to ideal with out a wideband and/or a dyno.
i have never driven a 300 hp turbo honda before, but i have driven a 500 hp 71 chevy nova, a 450 hp 64 corvette, a 550 hp 66 corvette, and a 250 or so hp turbo integra... so i think i could handle it, i do have access to a dyno, and i was planning on getting a wideband. would it be worth the extra $700 or so to step up to an AEM ems over the hondata?
