my civic needs help!
Old Dec 24, 2002 | 01:09 PM
pinoyboy204's Avatar
Default my civic needs help!
Hello everyone... i'm just wondering why when i start my car it idles and then idles iradically. my uncle said it was a vaccum hose..can anyone back me up on this? the engine is warmed up and its not cold. i need my car fixed!! thanks for any info on what i can do!
Mark
btw, its a 90 honda civic std 4 speed tranny w/ dpfi
[Modified by pinoyboy204, 10:10 PM 12/24/2002]
Old Dec 24, 2002 | 02:03 PM
DB'd's Avatar
Default Re: my civic needs help! (pinoyboy204)
Not trying to be mean but waht i think u should do is get a new motor b16 or zc or ls whatever but 4speeds suck man get a faster motor!
Old Dec 24, 2002 | 02:08 PM
Default Re: my civic needs help! (Hondacrx1990si)
it sounds easy if you have the flow..if you dont..then whats to go? i need to fix this....its my winter beater.
Old Dec 24, 2002 | 02:20 PM
Redline130's Avatar
Sounds like a bad IACV (Idle Air Control Valve). It should be located somewhere on the intake manifold. It should have 2 hoses on it, that contain coolant. Basically, the IACV allows extra air into the intake manifold during cold starts to allow the motor to get to operating temp quicker. Often, when a IACV goes bad, fluctuating idle is a symptom.
Old Dec 24, 2002 | 11:55 PM
Default Re: my civic needs help! (cyber13)
how would i be able to fix the problem? is the 2 hose loose or soemthing? could it be the air box filter??? let me know...
Mark
Old Dec 25, 2002 | 12:21 AM
gregv's Avatar
this problem is usually associated with engine swaps, and it can be caused by
a bad eacv , vacuum leaks or about twenty other things. If you do a search on this
site you will find a wealth of info from people who have had this problem.
good luck
P.S. for the time & cash involved, clean the intake inside & out with carb or throttle body
cleaner (especially the eacv, but make sure to let it dry before putting it back on) and
replace all of your vacuum lines. This would be a good start.
cheers
Old Dec 25, 2002 | 05:51 AM
civicwagonman's Avatar
Default Re: my civic needs help! (gregv)
might just need to take it off and clean it out with carb cleaner.
Ali Tohma
16
Aug 9, 2016 11:22 AM
Rat Rod
Feb 9, 2011 08:20 AM
ej63_civic
Aug 28, 2008 08:04 PM
FrekSdn
Aug 2, 2004 09:48 AM
ic0n
Aug 2, 2003 07:36 PM
