Stress on turbo motor
Old Dec 24, 2002 | 05:14 AM
Lsos's Avatar
Default Stress on turbo motor
I was looking at a dyno graph of the new Neon, and I noticed the torque peaks really low and then drops off by like 100lb-ft. I imagine it's simply a small turbo.
So, let's say the turbo would be upgraded such that the torque would be level all the way to redline. I extrapolated that the car would make closer to 300hp then. Would you say there'd be any more stress on the engine? I mean, the horsepower would drastically increase, but the torque and redline wouldn't...it seems like there should be absolutely no more stress on the thing. Am I correct in thinking this?
Old Dec 24, 2002 | 05:25 AM
glagola1's Avatar
Default Re: Stress on turbo motor (Lsos)
Nope. Often times when a motor makes a lot of torque it sacrifices the high rpm power. It has to do with the head design and the valve train design. The intake manifold also plays a role. It is the combination of these parts that is the problem. Even if you boost it with a different turbo you will still have that characteristic of low end torque and high rpm weakness.
Hondas don't have torque and it's because they are designed to rev. V8's have torque and they aren't designed to rev. VTEC and other types of valve "tricks" are designed to widen the power band. The GSR intake mani goes one step further by having two different runner lengths.
It's a system made of several parts. I suppose if you got a large turbo that didn't spool too quick and spooled higher up you could level out the torque a bit but it would be at the cost of low rpm torque.
I hope this answers your question a little bit. Oh, and about the extra stress part. Any time you increase the hp of a motor you are putting more stress on that motor and any time you rev the motor higher, you are stressing it more.
Old Dec 24, 2002 | 06:30 AM
BudaKai's Avatar
Default Re: Stress on turbo motor (glagola1)
The only problem with that is the Neon tranny won't handle that much. torque
want2rally
Sep 15, 2005 04:15 AM
dunkd
Apr 25, 2004 02:48 PM
kysard
Mar 11, 2004 05:41 AM
spaghizzle
May 1, 2003 07:11 PM
PrecisionH23a
Oct 28, 2002 08:14 AM
