What size injectors and what fuel pump on a b16 running at max 18 psi?
Assuming you have control over a big injector (hondata, ems, etc...) I would go with a bigger injector. Maybe 720cc or so. Better to go too big than too small!
Injectors max out at a particular hp, not boost. If you are making 250hp at 15psi, they are fine. If you are making 450hp at 15psi, they are too small...
440cc and you max out at 12 psi??? I run 440cc and I am nowhere near maxing out at 1 bar.
xxscaxx
Mar 8, 2005 02:16 PM
