Axles wont go in, help!!!
Old Dec 23, 2002 | 01:48 PM
Digitalcivic's Avatar
Default Axles wont go in, help!!!
I'm finishing up my clutch install and the axles wont go all the way in. Both the new one and the old one go in until there is about an 1inch gap. I'm lost. All the teeth on the axles look fine, and they are the right spline.
[Modified by Digitalcivic, 10:48 PM 12/23/2002]
Old Dec 23, 2002 | 04:34 PM
Stop the Beast's Avatar
Default Re: Axles wont go in, help!!! (Digitalcivic)
Smack 'em in real hard to overcome the snap ring pressure.
Old Dec 23, 2002 | 04:43 PM
boostinb18's Avatar
Default Re: Axles wont go in, help!!! (FFgeokstar)
yah.... some times you have to give em a good smack and make sure the old snap rings arent in the tranny.
good luck
Old Dec 23, 2002 | 05:05 PM
XEF-9X's Avatar
Default Re: Axles wont go in, help!!! (boostinb18)
just give it a good old hard push!!
Old Dec 23, 2002 | 05:16 PM
90_Civic_Hatch's Avatar
Default Re: Axles wont go in, help!!! (XEF-8X)
you need 1 person to hld it very steady, and one person with a sludge hammer. make sure its going in straight though.
ScottEK's Avatar
Are you talking trans side or hub side, trans side do the smack, hub side takes a lot more smacking then once you are sure they are correctly aligned with the splines and there is enough thread for you to start the hub nut you can usually just use the hub nut to pull it through. Grease the splines might also help a tad.
Old Dec 23, 2002 | 05:26 PM
XEF-9X's Avatar
Default Re: Axles wont go in, help!!! (90_Civic_Hatch)
umm bad idea. no sledge hammer!!! they are not that hard to push in. u only need one person. it just a takes a good hard quick pop and then it goes in!
Old Dec 23, 2002 | 05:43 PM
shortyz's Avatar
take em back.
i had the same problem.
they should go in pretty easy with a few smacks. if they dont take them back and try another set.
i made the fatal mistake of using someones advice on here to use a 2x4 and a sledge on the boot cup, RIP. dont do that.
CV's aint meant to hit with a sledge.
Old Dec 23, 2002 | 05:55 PM
ScottEK's Avatar
Default Re: Axles wont go in, help!!! (shortyz)
take em back.
On the metal boot cup, that is what I did. I didnt use a sledge hammer but I found the boot cup as a nice area to get a square hit.
Old Dec 23, 2002 | 09:36 PM
Default Re: Axles wont go in, help!!! (beta13)
yea, I was just being too gentle with um. One good smack and the went right in..
later on
Capt. Jimbo McSubipants
Sep 15, 2005 11:26 AM
DC2 to AP2
Jul 6, 2004 11:11 AM
ECKOTYPER
Apr 12, 2004 05:39 PM
mongoliandonuts
30
Feb 15, 2004 09:51 AM
MugenGTR
Jul 24, 2002 08:43 AM
