97 ITR with failing clutch? (Help me out please)
Old Dec 23, 2002 | 04:06 AM
JSITR's Avatar
Default 97 ITR with failing clutch? (Help me out please)
First off, thanks for taking a look and being willing to help me out. I searched, but could not come up with a definitive answer to my questions, so here goes.
I have a 97 ITR w/ 52K miles. Latley I have noticed the clutch start to slip every once in a while. I have also started to notice a "ringing" sound just before the clutch engages. Both these symptoms do not happen all the time, Id say 50 percent of the time. Is there anything I can do to try and fix this issue without having to replace the clutch? Is it the clutch? I dont mind replacing the clutch, but I dont know what to purchase. I would normally go with stock parts, but since the clutch failed with only 52K miles on the car, I would prefer a slightly more aggressive clutch, and mabey a lightened flywheel, for better throttle responce. Lastly, what exactly is involved with changing out the clutch IE: clutch, flywheel, throw out bearing etc. Thank you in advance for your assistance and happy holidays to you and yours.
Old Dec 23, 2002 | 04:09 AM
Bbasso's Avatar
Default Re: 97 ITR with failing clutch? (JSITR)
Some of your answers are here : https://honda-tech.com/zerothread?id=365819
Old Dec 23, 2002 | 04:25 AM
JSITR's Avatar
Default Re: 97 ITR with failing clutch? (Bbasso)
Not the same issue, I have no problem with the clutch engaging early, matter of fact it engages a little higher than what I am used to. Thanks for the info though.
Old Dec 23, 2002 | 05:57 AM
sackdz's Avatar
I recommend the Exedy Organic. It has almost the same feel as stock but has increased grip. I replace my factory clutch at ~38k and 25k later it's doing fine, with plenty of track use. As long as you're in there do the flywheel for sure. I have the Spoon chromoly but really anything light will do.
To change the clutch/flywheel/throwout you need to drop the tranny. With a helms and the right tools it's not a tough job, first time expect a few hours work.
Old Dec 23, 2002 | 06:00 AM
JSITR's Avatar
Default Re: 97 ITR with failing clutch? (sackdz)
Thanks again for all the info, what parts do I need to purchase to do the job? How much am I going to spend?
Old Dec 23, 2002 | 10:19 AM
COREY ITR#625's Avatar
Hey John, I know a guy that would put your clutch in for a good price. He is the one that replaced the valves in my ITR. I'll call you after the holidays and about the steelies I have and tell you about him. He does good work.
Old Dec 23, 2002 | 11:09 AM
JSITR's Avatar
Default Re: 97 ITR with failing clutch? (COREY ITR#625)
Thanks Corey. Please give me a call sometime after the Holidays and we'll talk.
Old Dec 23, 2002 | 11:18 AM
Dirt's Avatar
OT: Was your R was for sale back in July? for keeping it. Exedy Organic like Ed says is a good choice. Im still on OEM but for $265 its cheaper than OEM replacement and has a good reputation.
Old Dec 24, 2002 | 03:43 AM
JSITR's Avatar
Default Re: 97 ITR with failing clutch? (BrewCityR)
Yea it was for sale a few times. I just like something different about every month. For me its a love/hate relationship with the R. One minute my back hurts and my ears are ringing and I think I need something else. The next minute Ill come upon a set of challenging twistys and Ill fall in love all over. I think Im just gonna keep it and buy a daily driver. Need to build a bigger garage.
Old Dec 24, 2002 | 07:32 AM
Smitdog's Avatar
Go with ACT Heavy Duty Pressure Plate and a Street Disc, same feel as stock and grabs better then the Exedy.
.... who has nothing but problems since my exedy Organic Clutch. Adjust that and this..................
Buy an ACT u have no problems and it will take any abuse!
bigfinderman
Mar 15, 2012 03:53 AM
xunkn0vvnx
Mar 9, 2005 01:47 AM
Beave0101
Mar 23, 2003 08:36 AM
rluder21
Dec 21, 2002 06:03 AM
Brett
Nov 15, 2002 01:18 AM
