Crx Hf with 93 integra disk?
Can the rear disk assembly from a 93 integra all bolt up and work, I see lots of post about si crx's but is the hf the same, and what all do I need, I have the whole car so parts is not a problem what all should I transfer, thanks.
So the hf e brake cables will not work, will the teg cables work
dude you have a piece of gold in your hands right now! The Integra rear disk will bolt right up, and just use the teg cables, the front spindles will fit since the brakes and caliper is bigger, the master cylinder and booster will also fit, which will give you better braking power, also offcourse the engine will fit with a B-series mount kit, steering wheel will fit, and alot more should fit, just play around with it. Good luck!
yes I know, it truly is a gold mine. Does anyone know if the tie rods rack and pinion and all the steering stuff is transferabl, my crx stuff is gfarbage and shakes like hell when accelerating, thanks.
Living up to the latter portion of your name
Do a search, all the suspension peices of the HF/DX/Si are interchangeable.
[Modified by CRX-RX, 11:13 PM 12/23/2002]
I am talking about the integra steering parts, not crx, I know crx stuff is interchangeable, and.......what you dont like my user name.....tuff sh*t.
I don't like what you plan to do, not your name. I am well aware you are looking to install integra parts, but you asked:"I see lots of post about si crx's but is the hf the same", I gave you an answer. Do a search.
The reason why I asked is because my freinds si has rear disk already, thats why I wasnt sure if it would work on the hf since I have drums.
you can use the teg brakes, I would just swap the rear hub to your lower arm I think, I've heard of people having trouble with car too high or couldn't align right when swapping the whole arm.
also, gotta have the disk emergency brake cables, the ends are different. the crx ones are shorter.
[Modified by civicwagonman, 6:56 AM 12/25/2002]
darchon
Sep 6, 2005 07:02 PM
b16crx0062004
Aug 27, 2004 10:18 PM
andrew dc
Feb 21, 2002 07:51 AM
