How do I install rear lower tie bar on 94+ 4-door Integra?
I bought a rear lower tie bar and was about to install it, thought the bolts bolted right up but there seen the be stuff that is preventing me........I think they are call lower control arms?
I need instructions on how to install them or tips. This is for a 4-door Integra, 94+ Thanks!
Bump.
I've wanted to get one and I know there's something you need to do to get it fit but I don't know how either.
Yes ,... Unless you get a combo package that has a special bracket ... like Suspension techniques sway bars +rear lower strut then you have to #1 Get longer Bolts ... and #2 get cylinder style spacers (im not sure exactly what they are called ) (like a washer .. but its long and thick kinda like a socket ... and the bolt slides through it) you need some that are about 1" in length .. so thats about how much longer you need the bolts ... that gets it out of the way over everything else ..and allows you to lock it down they are cheap.. just a little hassle draggin old bolts to the hardware store and finding the right length and thread ..
For mine, i had to remove the bolts which held the abs cables. Some bolt up from the bottom up. There are several lower tie bars out there so it depends on which you have.
On the Neuspeed lower tie bar I got, you had to remove the ABS brackets and cut a small piece off the lower section of the bracket so that the lower tie bar would fit.
I bought a matrix rear lower tie bar, didn't came with any screws or anything. The guy at the shop told me it bolts right up but apparently you have to remove some stuff inorder to install it.
