H&R Eg Civic springs, Which ones are front?
I just picked up a set of Eg H&R sport springs and i need to know which ones are the front and which ones are the rear. They are marked in pairs as: KBA-Nr. 90 424 29 863 VA and the other pair is the KBA-Nr. 90 424 863 HA. Can some with these springs tell me which ones are front and which ones are the rear. thanks
the two that have evenly spaced coils and then a few coils at the top really close together should be the rears. the springs with evenly spaced coils throughout are the fronts. for H&Rs, if i remember correctly, when they're still in the box, from left to right, its: rear, front, front, rear. good luck with your install.
-alan
-alan
the longers ones go in the front, i think.
so does that mean the fronts are linear? cuz my h n r's are progressive for all 4.
-alan
-alan
I installed the springs and I just wanted to post this for future reference. I dont remember if HA or VA is front or rear however you can tell by this: Front springs are always flat on the top coil and rear springs are normally round on the top coil. Thanks for you help.
AllmotorGSReg
Apr 23, 2009 05:57 AM
BlackHXCoupe
May 2, 2007 02:32 PM
