Cant get alternator out
Old Dec 22, 2002 | 10:45 AM
Ef Whore's Avatar
Default Cant get alternator out
What is the easiest way the snake the alt. out of the engine bat w/out taking out the axle--this is annoying as f@*k.By the way stock a6.
Old Dec 22, 2002 | 12:03 PM
excitid's Avatar
Default Re: Cant get alternator out (Ef *****)
I pulled the bolts on the master cylinder and moved it carefully to the side and I also took off the the bracket that the top alt bolt goes into. Be very careful if you decide to go this route I assume it would be a pain to have to replace those brake lines.
Old Dec 22, 2002 | 12:10 PM
Ef Whore's Avatar
Default Re: Cant get alternator out (excitid)
thanx but i just finally dialed in my brakes so i'm not messing with em, i guess i have to pull the axle....great ..... if anyone else can help me i'd appreciate it.
[Modified by Ef *****, 9:11 PM 12/22/2002]
Old Dec 22, 2002 | 12:45 PM
crxaddikt's Avatar
before taking the axle apart, read this older post, cause it has two ways to get alt out without taking out axle, actually i am about to have to go out and take my alt out for the first time today also, but readiing the older posts under "search" helped, but read this: https://honda-tech.com/zerothread?id=343302
Old Dec 22, 2002 | 02:02 PM
Ef Whore's Avatar
Default Re: Cant get alternator out (crxaddikt)
thanx addikt I am gonna try the drivers wheel off/splash shield method when i return from pep boys.
[Modified by Ef *****, 11:03 PM 12/22/2002]
Old Dec 22, 2002 | 03:13 PM
vtecrx's Avatar
just remove the lower alternator to block mounting braket and you can get it out.
Andy
Old Dec 22, 2002 | 04:16 PM
I Gotta Question's Avatar
Default Re: Cant get alternator out (vtecrx)
Pull your oil filter and get it out.
Old Dec 22, 2002 | 09:15 PM
E-lude78's Avatar
I took out my alt. out of the driver fender side. but u have to remove the alt bracket attached to the block..oh yeah take off the driver side wheel too
Old Dec 22, 2002 | 09:36 PM
boostinb18's Avatar
Default Re: Cant get alternator out (Mista B-one-seven)
just to let you know... when you unbolt the master cylinder, as long as the lines are still connected, you dont need to bleed the system... you are not letting air in or anything.
Old Dec 22, 2002 | 09:38 PM
riceboy's Avatar
Default Re: Cant get alternator out (boostinb18)
you can move the master cyl, nothing will happen, as long as you put it back when your done
david420
Aug 2, 2012 04:29 PM
jeddy0120
Nov 8, 2007 06:55 PM
trianglegreg
12
Feb 6, 2007 06:31 AM
HU MAN CHU
May 7, 2006 09:53 PM
unknownhero16
Dec 27, 2003 05:41 PM
